LJ axle upgrade and re-gear questions - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > TJ Wrangler Technical Forum > LJ axle upgrade and re-gear questions
Engo winches available at www.rockridge4wd.com! Free shippTJ Dana 60 - BOLT IN REARSpartan Locker Promo Running now @ ROCKRIDGE 4WD plus FREE
Unread 01-19-2009, 12:02 PM   #1
gcally
I am lost when it comes to upgrading my axles and gears in my 04 LJ. I am going to be running 33’s so I want to upgrade the axles and gears to something that will work good off-road and on-road. I did a lot of searching but I am still totally lost on what route to go. I know that I want lockers front and rear and I do not want to be stranded on the trails! Also should I be looking to upgrade the gears in the transfer case?
gcally is offline   Reply With Quote
Unread 01-19-2009, 12:09 PM   #2
Unlimited04
Read tech links in my sig
Unlimited04's Avatar
go with 4.88 gears in the axles. you've already got a LSD in the rear. if you want to upgrade to lockers front and rear, go with selectables if you have the money. OX, Elocker or ARB, depends on your preference. if you don't have the money for selectables, then you have the choice of a lunchbox locker, TrueTrac or a Soflocker Detroit Locker.
your t-case will be fine, however a SYE will increase the torque capacity and if you land on the driveshaft, it will break a ujoint so you can limp home on FWD. if you land on your stock driveshaft there is a good chance you'll yank the slip yoke out in one piece spilling fluid all over the trail.
Unlimited04 is offline   Reply With Quote
Unread 01-19-2009, 12:09 PM   #3
Pillswoj
The axles you have will work great for 33" tires, given you have the 4 spd Auto you will want to regear from the 3.73's you have now to 4.56 or 4.88 ratio. Your transfer case is currently 2.71 ratio it should be fine for offroad with the auto. As to lockers, you will want to do them at the same time you regear so you are not paying twice for labour. Depending on your budget you could go Selectable, full case detroit, or lunchbox (most expensive to least). Given you have the Dana 44 in the rear if you are only going to lock one axle , lock the rear.
Friends don't let Friends run Bosch
Pillswoj is offline   Reply With Quote
Unread 01-19-2009, 12:36 PM   #4
gcally
Thanks for the info. I am trying to build a LCG rig. So I currenty have a 2.5 OME lift with JKS body and motor mount lift, Rokmen adjustable control arms, Rokmen sliders and full corners, JKS front Track Bar, Currie Antorock sway bar, and Currie HD steering. My play is to run 33’s for now because the jeep is also a daily driver and run 35’s when it becomes all off-road. I am planning to get a SYE and drive shaft when I get the Rokmen Tummy tuck and skid plates (should be soon). I do have a 4 speed Auto
Will 4.88 also work well with 35’s
Will the 4.88’s work well on the highway?
Will the front and rear axles be fine for 33’s (do I have to upgrade them to chrome molly?)
What is a Super30 kit and do I need one.
Do I need to purchase any other parts other than the gears and the lockers?
Thanks for all the help!!
Unread 01-19-2009, 12:49 PM   #5
Unlimited04
Originally Posted by gcally View Post
Will 4.88 also work well with 35’s - Not with the 42RLE.
Will the 4.88’s work well on the highway? - with 33s...yes; with 35s...no
Will the front and rear axles be fine for 33’s (do I have to upgrade them to chrome molly What is a Super30 kit and do I need one. - No, you'll be fine with 33s.
Do I need to purchase any other parts other than the gears and the lockers? - Do not buy the gears. have a shop buy them and install them, they will warranty the work, you want to pay the extra for this service.
See above, and like we already told you, your axles will be fine for 33s. once you go larger, you'll need upgrades. Because the deepest gearing you can go on the Dana 30 is 4.88s, and the 42RLE sucks, so you're limited by 33s if you want to drive on the highway.
Unread 01-19-2009, 01:02 PM   #6
gcally
That makes perfect sense.
Another option would be getting one of the TJ JK hybrid axles that Chrysler is supposed to offer. I know I would have to regear them but electric lockers would be much easier. Does anyone have any idea if these are going to be released?
Unread 01-19-2009, 01:09 PM   #7
Unlimited04
do a search on this forum. someone posted part numbers associated with them, they are going to be about $4100 EACH and will supposedly be available late 2009. You're better off with Dynatrac, Solid Axle or Currie for that kind of money.
Unread 01-19-2009, 01:14 PM   #8
gcally
I did not realize they were going to be so much cash. Looks like it’s going to be 4.88's and lockers for now. What are the best lockers out there that do not require air? I know that everyone likes the ARB lockers but I would rather not install a compressor.
Unread 01-19-2009, 01:19 PM   #9
Unlimited04
You've got 3 choices, air, electric or mechanically actuated. You said you don't want to install an air compressor, so that leaves you with mechanical or electric. The OX or Eaton ELocker, as indicated in post #2.
Unread 01-19-2009, 02:05 PM   #10
silverjeep
I'm putting an Aussie Locker in my LJ front axle this weekend and leaving limited slip in the rear. I run 33's and drive all highway with my 3.73 gearing. Not the best but not bad. IMO. I do have a six speed. I hope to regear when I go to 35's to 4.88's. Aussie Locker from Northridge was 260 shipped. FYI.
CHECK OUT MY LJ BUILD THREAD
silverjeep is offline   Reply With Quote
Unread 01-20-2009, 08:48 AM   #11
Axkick
A.K.A Ron
Axkick's Avatar
I am running 35's with 4.88's and love it..I have a detroit locker in the rear and im open in the front. I ran 33's for a while and it works great that way also. If i had the money i would of went with ARB lockers front and rear. For now my setup has taken me everywhere i needed, when i find a trail i can not get through its time to upgrade.
Axkick is offline   Reply With Quote
Unread 01-21-2009, 09:11 AM   #12
Terrain Twister
Sorry unlimited, but I have to disagree. I run 4.88's and 35's and for MY situation, I think it's a great combo.
This is a debate that will always go on.
Personally, I don't wheel the rocks and I think the 4.88 gearing works good because of that. On the freeway, I'm about 200 RPM higher than I was with stock. IMO, this is perfect since the tires weigh more and you need a little more UHMF to get them moving. I do the fire trails, water crossings, some hill climbing, etc. and don't have any issues with there not being enough power. Now if I was doing the rocks and such, I'd have to say 5.13. You'll want more at the lower speeds to get you over the obstacles. You also need to change the front axle to a 44. But you sacrifice highway speed in exchange.
As far as the trans, put a cooler on it, keep it maintained and drive it. Many here don't have any problems with it.
At that point where it's too much to list!
Terrain Twister is offline   Reply With Quote
Unread 01-28-2009, 11:07 AM   #13
gcally
Thanks for all the help, but I need to start over.
I now have now changed my build to include running 35’s. I thought I had everything figured out but now I am back at square one. I did a lot of searching for my options but I am still lost. I will be using the LJ for DD and a lot of off-road, so I want an axle that will hold up to 35’s. I do not plan on going any bigger than 35’s. I also need to keep the 4x4.5 bolt pattern.
HP30
Upgraded axle shafts (27 or 30 inner?)
ARB or Eaton Elocker
4.88 gears
What other stuff do I need to make this as strong as possible?
Custom build Dana 44 from Currie Enterprises
Comes complete with Chromalloy shafts, ARB, 4.88 gears
Is the custom built Dana 44 going to be that much stronger than the HP30?
I am looking for my best front axle option with keeping the 4x4.5 bolt pattern. I am clueless when it comes to axles so a list of the best setup would be great.
Unread 01-28-2009, 01:24 PM   #14
silverjeep
Easy on the skinny pedal and keep your shafts. Upgrade later or when they break. You said mostly on road driving. Get wheels with proper back spacing or spacers. Re-gear to 4.88's. ($1000) Add and Aussie locker in the front. ($269) You will need at least a 4" lift to get decent flex with 35's. ($800-1200) 1.25 JKS Body lift. ($125) Good to go. That's the route I'm going and upgrading slowly. I don't have a bunch of money to throw.
or
33's with Rough country 2.5" lift( $400), 1.25 JKS body lift ($125), Aussie locker ($269), wheels with proper back spacing or spacers. Keep you 3.73 gears until you have more cash. They are not optimal but I have been driving them for 2 yrs all highway. Not to bad unless you want to pass.
Unread 01-28-2009, 01:31 PM   #15
gcally
or
I really like doing everything at one time to save some cash in the long run. Here is a link to my build thread.
http://www.jeepforum.com/forum/f9/gcally-lj-build-680123/
I defiantly want to build an front axle with an ARB or Elocker that will hold up to the 35’s off-road.
