A little angry please help!! - JeepForum.com
post #1 of 14 Old 06-20-2007, 06:30 PM Thread Starter
xulcuz
Ok this is making em really made I have gone through 3 trac bars in about 3 weeks. The first one I out on when putting on my lift and went to test it after I was done and got death wobble over some rail road tracks right in forn tof the warehouse were it was installed and it snapped at the adjusting part. I bring it back tehy refund it and all is good. I decide to take it up to the dunes. What do you know it snapps while I'm an hour and half away from home at the same spot. so I weld it together at the dunes so I could limp home. After driving it home I had no doubts in my welding and all though dumb I rpecedeed to drive it because it is my daily driver and I have nothing else. SO tonight Im driving into my driveway and I hear it snap and I figured it was the weld but no it snapped at the end of the adjustable part this time next to the weld. So wtf? Im sick of replacing trac bars left and right and worrying about when its gonna snap again. Oh and its a bds tracbar. Any help on why I keep snapping it would be awsome! Thanks
xulcuz is offline
post #2 of 14 Old 06-20-2007, 06:52 PM
ROXN4LO
What brand?
2001 TJ Sport: 4.0L, NV3550, D30/D44, 35x12.50x15 Maxxis Trepadors on DC-1s, 4.56 gears, Cromoly shafts & ARBs F/R, Full Traction 3" Lift, 1.25" JKS BL, Jeeperman Tire-Carrier Rear Bumper, Jeeperman Receiver/Winch Front Bumper, B&M Shifter, Kilby Gastank Skid, TBT Steering Skid, Nth° OPS, TBT Rock Steps, SkidRow Radiator skid,, IPF H4 (Fatboys), KC 100W Driving SlimLites.
ROXN4LO is offline
post #3 of 14 Old 06-20-2007, 07:31 PM
deltabravo
sounds like a junk track bar if they keeps breaking. time to switch to a new brand.
deltabravo is offline
post #4 of 14 Old 06-20-2007, 10:19 PM Thread Starter
xulcuz
Well they have replaced all of them under wareenty but this time I think Im just gonna say screw it im changing brands. Its a BDS right now but is there any reason besides brand why it would be happening?
xulcuz is offline
post #5 of 14 Old 06-21-2007, 01:14 AM
GringoLoco
GringoLoco's Avatar
Are you installing the track bar with the Jeep up on jack stands, or on the ground with its full weight on the tires?
YELLOW Jeep Club Member #5606
13 mpg - edit: 12 mpg
No hi-lift on the hood (yet)
Odd noises
Still can't get it to take off from a treadmill....
GringoLoco is offline
post #6 of 14 Old 06-21-2007, 05:59 AM
blacksheep1
I wonder if you have some sort of clearance issue. Mine for example will conact my diff cover under certain conditions. I would check out some pics of jeeps with your setup, or better yet a jeep local to you, just to make sure everything is mounted correctly.
Another thing you can try is to jack it up and have someone steer it from lock to lock while you watch for anything that might contact. If you can jack it up on each side to cause it to flex and again steer lock to lock that would be ideal.
I just can't believe that BDS trackbars are THAT weak, maybe they are made in china like thomas, pet food and toothpaste. Good Luck HTH
3 Jeep family again.
MINE 1999 TJ sport, HERS 2004 KJ Renegade and 2005 Rubicon
Wind Tunnel Tested . . . FAILED
blacksheep1 is offline
post #7 of 14 Old 06-21-2007, 06:16 AM
ROXN4LO
As said above, be sure it's being installed with weight on the tires, and check for clearance issues. BDS is not known for bad parts. Something else is going on here.
ROXN4LO is offline
post #8 of 14 Old 06-21-2007, 07:42 AM
spyder6
Got that Toyota chit
spyder6's Avatar
2010
ive got the Rubicon Express adjsutable track bars and they're very nice. the heim joints are large and solid and the rubber bushings are silent
My builds:
and
or follow us on
spyder6 is offline
post #9 of 14 Old 06-21-2007, 09:30 AM
Crashnburn80
Crashnburn80's Avatar
Fill in your profile so we know more about your setup. Because you mention DW I assume your talking about the front trackbar?
| 1.25" BL |
| Riddler diff covers |
| 33" MTRs | Warn M8000 |
and much more...
Crashnburn80 is offline
post #10 of 14 Old 06-21-2007, 09:44 AM
Wheelin98TJ
JEEP FREAK
Wheelin98TJ's Avatar
How much lift are you running and how much lift is the track bar designed to be used with?
How much of the threaded adjustable portion of the track bar is screwed in?
Wheelin98TJ is offline
post #11 of 14 Old 06-21-2007, 10:33 PM Thread Starter
xulcuz
Yes It was installed with weight on tires. Sorry its a Rubicon so it does have aa dana 44 so that may have somthign to do with it. It has a RE 3.5 standad lift with OME shocks and 33x12.50 pro comp Xterrains. When I get my new one installed tomarow I will take the advice and jack it up and see if it rubs any were. When i talked to the 4x4 guy again today he said I may be over articulating it but the first one I snapped was just drivin on the road and so was the third. Only one actually broke off road. Ill let you know when I get it on and see if it rubs at all. Thanks for the help guys I really apreciate it!
xulcuz is offline
post #12 of 14 Old 06-21-2007, 11:18 PM
jdragger
You might also have the front axle too far forward or back. This would could put a front load or rear load bind on the track bar besides its intended side load. You have got to have something miss aligned.
jdragger is offline
post #13 of 14 Old 06-22-2007, 08:00 AM
JeepRocks86
Some Call me RockDog
JeepRocks86's Avatar
I ran the BDS rear track bar and had no troubles out of it. They have a full replacement warrenty as well...
Stretched TJ , Coil overs, 42" IROKS, 60/14 bolt...
'95 YJ fuel injected 302, 8.8, cage, ARBs.
'04 QC LB Cummins 4x4
For Sale:
TJ Rear Dana 44 shaftsfor sale
3 11"& 2 13" BBCS shocks
JeepRocks86 is online now
post #14 of 14 Old 06-22-2007, 08:09 AM
mrblaine
Wizard of Brakes
mrblaine's Avatar
A few pics of the front suspension would sure go a long ways towards helping to diagnose the cause.
You have something wrong somewhere and it's not the quality of the trackbar.
I am Savvy
blackmagicbrakes.com
mrblaine is online now
Angry Sparrows Hitmanx800 TJ Wrangler Technical Forum 10 04-26-2012 07:36 PM
What's this and why is it so angry? Fropleyqk TJ Wrangler Technical Forum 81 03-23-2010 04:09 PM
Angry Swallows jepmn03 TJ Wrangler Technical Forum 19 03-02-2009 10:09 PM
Uh oh, angry sparrow is on to me jzmtl TJ Wrangler Technical Forum 8 06-11-2006 05:56 PM
Angry Sparrows still there!!! jeepaholictj TJ Wrangler Technical Forum 1 06-07-2006 09:06 AM
