Little 4cylinder question - JeepForum.com
post #1 of 23 Old 07-28-2013, 06:16 PM Thread Starter
rileysTJ
I just bought a 97 4 cylinder tj and i really want to throw some new tires/wheels on it. My question is, what is the biggest tire size this engine can handle? Thanks in advance
rileysTJ is offline
post #2 of 23 Old 07-28-2013, 07:28 PM
MO2500
As big as you want, but it is all about gearing. Factory gearing should be 4.10 on your Jeep if it is a 5 speed.
If keeping the factory axles, 33" tires with 4.88 gearing is a pretty good all around combo for the 4 cylinder. 4.88 is as low as you can go with the factory axles which is why I wouldn't recommend larger than a 33" tire if you want to maintain near stock street/highway manners. 35" tires and 4.88 gears is okay but a little under powered. 5.13s would be better for 35s but would require an axle swap front and rear.
Gearing is important with these little engines. The factory gearing is only okay for about a 31" tire, above that, consider a regear at the same time IMO. I ran 33s for about a year with 4.10 and it was okay but highway performance suffered a lot. 4.88s and 33s was perfect. FWIW, my 4 cyl Jeep is no longer street legal and doesnt get driven on the road but I'm currently running 37" tires with 5.38 gearing and feel it would perform well on the street/highway if I did.
Instagram: @omsmike
MO2500 is offline
post #3 of 23 Old 07-28-2013, 07:41 PM
TripLeader
I suggest 31s. You can put them on without any lift. If you add a two inch lift later they will still be good to go.
TripLeader is offline
post #4 of 23 Old 07-28-2013, 08:00 PM
tyvanwie
If anyone knows, it's this guy right here.
tyvanwie is offline
post #5 of 23 Old 07-28-2013, 08:29 PM Thread Starter
rileysTJ
Im not looking to go bigger than 33s, as of now at least. What kind of price range would i be looking at for a regear?
rileysTJ is offline
post #6 of 23 Old 07-28-2013, 08:37 PM
tyvanwie
~$1000 for both axles. Depends on the shop though. I've heard a wide range of prices.
tyvanwie is offline
post #7 of 23 Old 07-28-2013, 08:38 PM
gst95dsm
Chop, Wheel and Rebuild..
gst95dsm's Avatar
4cyl's rule! Price for re-gear between a 1000 and 1500, parts and labor.
gst95dsm is offline
post #8 of 23 Old 07-28-2013, 11:29 PM
armyRN
armyRN's Avatar
Location: Longview, WA (one hour north of Portland, OR)
1998 TJ (pictured here in Moab) with 2.5/5-speed/3.5" RE lift/285/75/16" (33x11.5") tires/4.88 gears (and a bunch of other stuff). 4.88 gears and 33" tires are the sweet spot for four-cylinder TJs. It brings it back to the same ratio as the factory size tires and gear ratio. You're not slipping the clutch around town, and you can use 5th gear on the highway and keep up with traffic. I wouldn't go larger than 33" tires with a four-cylinder TJ.
armyRN is offline
post #9 of 23 Old 07-28-2013, 11:57 PM
mkiv808
How do 30's feel with stock gears?
I was thinking of going with 235-75-15 to keep the acceleration and highway manners intact (mine came with tiny 205-75-15's), but I'm not sure if I need to go that small?
2001 Jeep Wrangler SE
2009 BMW M3 Coupe
mkiv808 is offline
post #10 of 23 Old 07-29-2013, 05:09 AM Thread Starter
rileysTJ
I'm running 30s on stock gears now and it feels good. Also, how much of a body lift can you go without starting to replace things?
rileysTJ is offline
post #11 of 23 Old 07-29-2013, 05:12 AM
tyvanwie
Originally Posted by rileystj
i'm running 30s on stock gears now and it feels good. Also, how much of a body lift can you go without starting to replace things?
~1.25"
tyvanwie is offline
post #12 of 23 Old 07-29-2013, 07:40 AM
GOVT1911
I'll agree with the guys saying 4:88 with 33s is the "sweet spot" for us with 2.5s. I regeared to 4:88 and ran 33's for a month and loved it, then ran across a smokin deal on some 35's and now run them. I won't set any land speed records, but the 35's give me a bit more clearance and since my TJ isn't a DD, it works for me.
GOVT1911 is offline
post #13 of 23 Old 07-29-2013, 08:00 AM
armyRN
armyRN's Avatar
35" tires will definitely give you more clearance than 33" tires. One inch to be exact. Even though there are two inches in height difference between the two tires, you gain one inch above the center line, and one inch below the center line. It's the one inch below the center line that gives you the additional clearance.
Just saying.....
armyRN is offline
post #14 of 23 Old 07-29-2013, 07:50 PM
aerotech
Junior Member
I've got a 98 TJ 4 cylinder automatic. I started out with stock gearing and 33" tires with a budget lift. Terrible on windy days or going up a hill, could not keep speed. I regeared to 4.88 and love it. Mind you it's still not a speed demon but hill and highway speeds no problem.
aerotech is offline
post #15 of 23 Old 07-29-2013, 08:11 PM
duc202
97 TJ here with 33s and geared to 4.10
just picked up my 8.8 at the beginning of july and awaiting gears to regear
duc202 is offline
