Linkage questions with 2" lift - JeepForum.com
post #1 of 8 Old 10-31-2013, 07:50 PM Thread Starter
jsalman93
Hi everyone, just got a jeep TJ last week and looking to doing a 2" lift on it for when i go up to the trails. I've heard that V8 ZJ coils will give about 2" of lift. I was wondering a few things though:
1) Would ZJ coils for the rear also lift up the rear end as well
2) Will I need to change out my shocks for this mod
3) Will I run into any issues with the transfer case linkage or shifter linkage
Sorry for the noob questions, it's my first wrangler. Thanks again
jsalman93 is offline
post #2 of 8 Old 10-31-2013, 07:54 PM
Jeffro06
Jeffro06's Avatar
1: no idea.
2: Yes.
3: No, a body lift is what screws that up.
Jeffro06 is offline
post #3 of 8 Old 11-01-2013, 09:42 AM Thread Starter
jsalman93
Also, would installing a 2-3" coil lift affect my top speed. I've got the 2.5L engine if that helps
post #4 of 8 Old 11-01-2013, 11:13 AM
rda616
You would be better off buying a 2.5" lift from rough country for a couple hundred bucks.
rda616 is offline
post #5 of 8 Old 11-02-2013, 01:57 PM Thread Starter
jsalman93
I would but i like the idea of having lift coils instead of spacers. If I want, i can get the spacers at work for extremely cheap, but i can also pick up some junkyard coils for 20 bucks and have more suspension travel. I am
post #6 of 8 Old 11-02-2013, 06:15 PM
rda616
Who said anything about spacers?
rda616 is offline
post #7 of 8 Old 11-04-2013, 10:13 AM Thread Starter
jsalman93
Oh my bad, I hadn't checked out their website. Most of what I've heard of their stuff involved lift spacers
post #8 of 8 Old 11-04-2013, 10:33 AM
afusco1222
RC springs are great because they are so long but their shocks really leave something to be desired. I would go with RC or OME springs and teraflex or OME shocks. I personally run Teraflex shocks in the front and OME nitrochargers in the back and though the teraflex shocks are pretty soft, they ride awesome on-road, are made by fox, and are 60 bucks a shock so much cheaper then most shocks of that caliber. The reason for running miss matched shocks is that I really needed more uptravel and my teraflex shocks were limiting. The OME shocks need a lot less bump-stops and if you want more travel out of your suspension, then OME is the way to go.
afusco1222 is offline
