Lights out behind gauges - JeepForum.com
post #1 of 4 Old 06-13-2013, 04:52 AM Thread Starter
jmcgin186
Hey how's it going. I have a 97 wrangler and last night the lights behind the gauges went out. When starting the jeep the check engine and all other warning lights come on but no backlight. The dome light and radio are fine. Any advice on what's going on? Thanks
jmcgin186 is offline
post #2 of 4 Old 06-13-2013, 06:58 AM
TheBoogieman
Disturbed
TheBoogieman's Avatar
Have you checked the fuse?
TheBoogieman is offline
post #3 of 4 Old 06-13-2013, 09:34 AM
NotURMailman
NotURMailman's Avatar
x2
If not the fuse, I would check the dimmer.
equipped... And loving it!
I drive on the right side, what's wrong with you?
It's difficult to take you seriously. It's like you're an easily perturbed autistic teenager who's drunk typing the whole time.
NotURMailman is online now
post #4 of 4 Old 06-13-2013, 09:43 AM
Jonny Jeep
Jonny Jeep's Avatar
First, check the dimmer isn't turned all the way down as already suggested.
Do the marker lights work?
If they don't, and one of them has failed and taken the fuse with it (#1 behind the glove box), you will loose the cluster and dash illumination.
If the marker lights are good and dimmer turned up, but still no dash/cluster illumination check fuse 12 behind the glove box.
See if that gets you anywhere and report back.
Jonny Jeep is offline
