Light problems - JeepForum.com
post #1 of 2 Old 02-09-2014, 06:17 PM Thread Starter
czebley24
Light problems
My headlights wont turn on. When I pull the switch to turn them on, the lights for the dash turn on and everything but the lights work. I recently installed a pair of rigid duallys and hella rallye 4000's. I dont know if they have anything to do with it but i have always had problems with my head lights. Like when I would go from high beam to low beam they would sometimes just turn off... Also one of my high beams doesnt work. 97' tj.
czebley24 is offline
post #2 of 2 Old 02-09-2014, 06:59 PM
Shark_13
If one of the high beams are out it could just be the headlight itself. If you have a test light or multi meter you can check voltage at the headlight plug.
It could be the headlight switch itself, or possibly the multi function switch. Check all the fuses too.
Shark_13 is offline
