Light behind fan speed switch/Temp Control - JeepForum.com
post #1 of 3 Old 11-23-2010, 10:04 PM Thread Starter
nuccman
I have a loose bulb located behind the fan blower switch. At night when I tapped on it it would glow/light the marking for the fan speeds and some of the temp knob. Anyway... Now it's not working at all. How hard is it to see/get to where that bulb would be? The right side bulb(s) are still working, but it's much brighter when the left side bulb(s) are also working...
Anyone ever mess with this? If so what/how much has to be disassembled to get to them?
Thanks in advance!
nuccman is offline
post #2 of 3 Old 11-23-2010, 10:09 PM
spdcat01TJ
I haven't specifically had problems with the lights, but I've changed the blower motor switch. It was very easy to get to. Pop off the long defroster cover at the windshield, then take out the 2 screws at the top of the center trim, and I think 2 screws down lower on the center trim panel, and pop it off. From there you should see several screws that hold the A/C controls in place. You should be able to see from there how to get to the lights. If I remember correctly, the light bulbs are behind the knobs and shine through them somehow.
If guns kill people, then pencils misspell words, cars make people drive drunk, and spoons made Rosie O' Donnell fat!
NRA Member
'01 TJ Sahara, 3" BB front, 2.25" BB rear, 1.25 JKS BL, 1" MML, Skyjacker Hydro shocks,33/12.50x15 BFG TA/KO All Terrains homemade disco's, Hi-Lift, CB, GPS
spdcat01TJ is offline
post #3 of 3 Old 11-25-2010, 12:08 AM Thread Starter
nuccman
Hey Thanks!!
I'll give it look to see if I can try to get to those bulbs/LEDs...
nuccman is offline
blower motor switch , fan switch , LED lights
want to change fog light panel switch with 4 wires to rocker switch with 3 terminals lomondpeak TJ Wrangler Technical Forum 6 11-28-2009 10:21 PM
Factory Fog Light Switch to Control Door Jam Defeat ghoekstra TJ Wrangler Technical Forum 1 10-28-2009 01:16 PM
Temp Control Light Replacement?? vfrpilot TJ Wrangler Technical Forum 14 01-31-2009 10:04 PM
Fan Speed Control Switch Part Number? Oman Jeep TJ Wrangler Technical Forum 0 08-28-2008 12:20 PM
3 Speed Auto Trans Temp BEANS TJ Wrangler Technical Forum 8 02-12-2006 06:58 PM
