lifter tapping is this common 4.0 - JeepForum.com
post #1 of 7 Old 09-20-2011, 05:03 PM Thread Starter
BadApple1403
I've had two jeeps a 91 with 160000 miles and now a 06 with 48000...both jeeps have had lifter tapping and was just curious if this is a common thing for the 4.0s..I also have a few friends with same engines and tap tap taparoo...also my jeeps are well maintained so its not like I'm neglecting oil changes or nething
BadApple1403 is offline
post #2 of 7 Old 09-20-2011, 06:57 PM
EJames1226
EJames1226's Avatar
I was gonna start a thread, mine does too and its getting worse so im looking for some threads on it.
I might give this a try
http://forums.noria.com/eve/forums/a...95/m/625105228
Damage Initiation Specialist: Eric's Jeep Repair Club, San Diego Chapter
EJames1226 is offline
post #3 of 7 Old 09-20-2011, 07:29 PM
Ej132
Subscribed.
Ej132 is offline
post #4 of 7 Old 09-20-2011, 07:40 PM
OsteKuste
I've had a '94 and now a '00, and those as well as most I've been around have some lifter noise. It may be due to the flat tappet cams used in our jeeps, as well as the thin sheetmetal valve covers. It's just one of those Jeep things. You could spend some money on a fancy aftermarket aluminum valve cover to quiet it down a bit, but I wouldn't worry about it.
OsteKuste is offline
post #5 of 7 Old 09-20-2011, 07:48 PM
Carlo
Mine is 2001 TJ sport with 140K miles. No tapping. And I bought the jeep used when it was 120K. I use regular dino oil 10W-30.
Carlo is offline
post #6 of 7 Old 09-20-2011, 08:04 PM
chris142
My 02 had a tap that would come and go. I thought it was a lifter. It was the Oil Pump Drive Shaft. It's bushings wallered out and the shaft was slapping around inside the housing.
chris142 is offline
post #7 of 7 Old 09-20-2011, 08:33 PM
black99
I own a 99 with 100k that doesnt have any lifter noise or tapping and my brother owns a 2000 with 140k that does have a bit of lifter noise, he's been driving it for about 20,000 miles now and hasn't had any problems. I guess its kind of a jeep thing.
Jeepin isn't a hobby, its an obsession
black99 is offline
lifter tapping fix? write up? greta TJ Wrangler Technical Forum 53 09-03-2010 02:24 PM
Engine Tapping mpd2434 TJ Wrangler Technical Forum 11 09-26-2009 03:27 PM
Need a Self Tapping Bolt HAARUBICON TJ Wrangler Technical Forum 3 04-06-2009 12:41 PM
Engine Tapping TWrangler TJ Wrangler Technical Forum 19 10-11-2006 06:21 PM
Stuck/tapping lifter on 03 4.0l 2003KhackiTJ TJ Wrangler Technical Forum 2 01-03-2006 05:30 PM
