Lifter Noise vs Piston Slap - JeepForum.com
 1Likes
post #1 of 43 Old 03-05-2008, 02:57 PM Thread Starter
weslaine
Hey fellow Jeep Brother and Sisters,
My 97 Wrangler has been making a tapping noise for over the last 8,000 miles. It has gradually gotten worse. I took it to used jeep dealer/mechanic - I thought I had a bad lifter/rod. He pulled the wires off two of the injectors while the motor was running - the tapping noise lessened but did not go away. He said this is more than likely a case of piston slap. How can I be sure?
My choices are: let it go and see what happens; pay him to pull the oil pan and valve cover,measure everything and check the lifters; pull it completely apart and remachine the motor & new bearings, or just put in a used/new motor.
Any recommendations? 162,000 miles.
Thanks
97 TJ Sahara Black
weslaine is offline
post #2 of 43 Old 03-05-2008, 03:54 PM
never monday
pull the pan your self and look up in there. There have been a rash of broken pistons. If one is broken you can get a used rod and piston and new rings for one cylinder, a gasket set. Then put it together and keep driving. If you ignore it, eventually it'll get worse and could punch o hole in the cylinder wall.
never monday is offline
post #3 of 43 Old 03-05-2008, 07:13 PM Thread Starter
weslaine
Thanks Never,
I'm mechanically inclined but not a mechanic. I'm not sure if this is something I can tackle on my own.
Anyone else have experience with Broken pistons? Piston Slap?
Is it better to buy a remanufactured crate motor or have my current motor rebuilt?
97 TJ Sahara Black
weslaine is offline
post #4 of 43 Old 03-05-2008, 07:48 PM
mich99TJ
For what its worth, my 2000 Neon with the 2.0 liter 4cyl has had piston slap almost since it was new. It now has 125K on it, and still makes the same noise every morning on cold starts. I have been told multiple times by reputable sources that its innocuous, just like lifter noise. At first I didn't believe them, but time has proven me wrong. Just my experience, you'll want to draw your own conclusions.
'99 TJ SE, 2.5 / Ax5 / NP231, D30/35, 4.11
Intense Blue, 31" BFG ATs Warn M8000 Winch, Cobra CB
'14 Cherokee Trailhawk, 3.2 V6, 9 Speed, Granite / Moroccan Black Interior, 8.4 AN, Trailer Tow
mich99TJ is offline
post #5 of 43 Old 03-05-2008, 08:14 PM Thread Starter
weslaine
Hey Mich,
My mechanic told me the very same thing. He said that I could probably run the motor for another 100,000 miles with the slap.
The difference is my slap is very loud when the motor is cold and ony slightly gets quiter when running at tempature. I would say even when the motor is hot the slap is still loud.
97 TJ Sahara Black
weslaine is offline
post #6 of 43 Old 03-06-2008, 07:47 AM
mich99TJ
At this point with your high amount of mileage, you are facing the decision 1) replace the engine, 2) rebuild the engine, 3) wait and see what happens.
The first 2 options are expensive, the third just prolongs the situation. It just depends on your own feelings on the risk of having the engine give up on you. I would personally ride it out since I'll probably have to replace it anyway down the road. On the other hand, if you are uncomfortable with the noise and it gets progressively worse, just address it now.
mich99TJ is offline
post #7 of 43 Old 03-06-2008, 09:26 AM
tebriel
tapping is usually a lifter, but if your jeep sounds like a diesel then it's piston slap.
tebriel is offline
post #8 of 43 Old 03-06-2008, 09:38 AM
tcourdin
tcourdin's Avatar
Sounds like piston slap to me. I've had a few new vehicles with piston slap when they were cold, it's pretty common these days. If you've got 162,000 miles you're gonna have a few noises! I'd forget about it and drive it.
I cant remember what kind of pistons we put in my Jeep when we rebuilt it, but the piston slap is pretty loud at startup, it goes away at operating temp though.
88 Wrangler, Rebuilt I6, NV3550,Atlas 2,B&M Shifter,38/38 Weber, Skyjacker Lift & Nitro Shocks & Stabilizer, Black Diamond Discos, 35 " Regul MT's & Outlaw 2 Alum Wheels, 4.88 Gears, Dana 35 & Super 35 kit & Detroit Soft Locker, Dana 30 & Superior Axles & Detroit Soft Locker & No Disco, SRC Front & Rear Bumpers, SRC Side Armor, Warn XD 9000 I Winch & In Cab Controls, OR Fab Tire & Can Carrier, Rock Hard 4x4 Full Cage, Hood Rack & Hi Lift & AX, Outland Seats, KC & Silverstar.
tcourdin is offline
post #9 of 43 Old 03-06-2008, 09:41 AM
Jerky bump
If you want to rule out valve train, remove the valve cover (if you dare). You can do some diagnostics there with the engine running. All I ever did is put my thumb on each rocker while it was running and it is very easy to feel if there is a problem.
If you can't find anything there, then look further down (or get someone else to).
Just an idea.
My jeep makes a ticking noise too
It has done it since it was new
I couldn't care less- I must confess
I use FRAM filters too!
Jerky bump is offline
post #10 of 43 Old 03-06-2008, 01:04 PM
tebriel
you can also use a stethoscope and place it on different parts of the engine to determine where the noise is coming from. you can also use a socket extension, it just doesn't work as well.
tebriel is offline
post #11 of 43 Old 03-09-2008, 10:37 AM Thread Starter
weslaine
Thanks Tebriel,
The mechanic put a stethoscope on the motor and isolated it to around the head. We both thought it was a lifter until he pulled off the wires to the first 2 fuel injectors and the knock didn't go away.
97 TJ Sahara Black
weslaine is offline
post #12 of 43 Old 03-09-2008, 10:45 AM
Jakemd98
Choosy moms choose jeep.
Jakemd98's Avatar
so that's what that is...
Jake Davis
97 Jeep Wrangler
4.0, 5 speed AX-15, D44 & Ford 8.8 w/Detroit - 4.88, NP-231, OME 2.5" coils w/1.25" spacers on front, 1.25" JKS BL, 35X12.50R15 KM2 on 15x8 Eagle alloys, Banks Header, Banks Monster Exhaust, Brown Dog MML, Rhino Liner, Tuffy Glove Box, AtoZ Rockers, Optima Red Top Battery.
1998 GMC Yukon
Jakemd98 is offline
post #13 of 43 Old 03-10-2008, 08:17 AM
tebriel
Thanks Tebriel,
yeah but would killing the power to the cyl really get rid of lifter noise? if it were the injector being super loud, it would stop that. but your lifters are compressed by rockers attached to push rods. right? let me know if i'm thinking wrong.
-teb
tebriel is offline
post #14 of 43 Old 03-10-2008, 08:45 AM
rxl
rxl's Avatar
Be sure that it's not as simple as an exhaust gasket or cracked manifold/header. I have seen this misdiagnosed before.
I'm sure you've ruled it out already, but just incase.
I bought "MY JEEP" for my wife
I bought "MY OTHER JEEP" for my daughter [she sold it]
I finally bought one for me
Canadian Jeep Club Member #7
99 GC limited
4.7 Quadradrive
97 TJ Sport
4.0 5 speed
99TJ Sahara
4.0 Auto
Sold to a life of blacktop
94 ZJ Limited
I6 Quadratrac
rxl is offline
post #15 of 43 Old 03-10-2008, 08:56 AM
LeftoverSalmon
LeftoverSalmon's Avatar
Had the same issue. It started as a light tapping only when it was cold out. Over a couple months the knocking got to the point it was sorta unbearable. Originally thought it was problably a lifter but turns out the bottom portion of one of the pistons had blown apart - found several large chunks of it in the oil pan. Im guessing that kinda threw things out of balance...
I bought a crate motor.... good opportunity to drop a stroker in there
joe_jeep likes this.
LeftoverSalmon is offline
Piston Slap or Rod Knock - How To Tell todd1803 YJ Wrangler Technical Forum 20 02-09-2012 07:58 PM
Noise from engine? piston slap? wrangler0415 TJ Wrangler Technical Forum 2 10-08-2009 11:54 PM
4.0L Piston slap gothemi YJ Wrangler Technical Forum 1 07-21-2003 03:07 PM
Piston slap The_'ster TJ Wrangler Technical Forum 1 05-16-2003 07:58 AM
