lifted tj alignment ???'s - JeepForum.com
post #1 of 4 Old 10-18-2004, 02:18 PM Thread Starter
rajincajingt
rajincajingt's Avatar
1983 CJ7
i am having trouble with my tj wearing the tires too quickly in the front.
what kind of alignment specs are you running and how are the tires wearing,
id like to guess that i have an average driving style, the tires are wearing more than twice as fast in the front as they are in the back.
i was told by the place that did my aligment check that i am at stock settings, i had some helpful info this weekend to run 0 toe in and 7degrees of caster
any input would be appreciated before i ruin another set of tires!!!!
thanks
matt
83 cj
70 commando
76 c30
rajincajingt is offline
post #2 of 4 Old 10-18-2004, 02:26 PM
ONE JEEPBRO
ONE JEEPBRO's Avatar
I don't know much about alignments, but how often are you rotating your tires? If you rotate your tires every 3,000 miles, you will get a lot better mileage out of your tires. Not that you don't know this (but I'll say it anyways), your front tires, being that they are the steering tires, tend to wear out faster because they do the majority of the work for the vehicle (IE: turning movements). Further they take up the brunt of the force when you brake (Weight transfer). Not to mention, off road tires tend to wear out faster because the tread lugs are spaced out more. Hope this helps you out!
JEEP: 2004 SILVER WRANGLER RUBICON
MODS: 4.5 RE SUPERFLEX / 33inch SSR'S / WARN REAR BUMPER / JEEPERS & CREEPERS T-BODY / J&C DUAL BATTERY SYSTEM / J&C FRONT & REAR DIFF GUARD / WARN XD9000i WINCH & RECOVERY GEAR / ARB BULLBAR / PSC FULL ROLL CAGE / L.E.D TAILLIGHTS / IPF 930 SUPER RALLY LIGHTING / COBRA 75 WX ST CB / POWER TANK PT-10 OBA / TOM WOODS C/V / GARMIN 60CS GPS
CURRENT PROJECT: Nth DEGREE ARMOR INSTALL
ONE JEEPBRO is offline
post #3 of 4 Old 10-18-2004, 02:27 PM
wayoflife
This should help you out...
Basic Front End Alignment Write-Up
wayoflife is offline
post #4 of 4 Old 10-18-2004, 03:02 PM
igofshn
Locked @ both ends
igofshn's Avatar
Look in the FAQ.
2007, 4 door, powered by a minivan engine, locked and riding on 35's.
igofshn is offline
Another alignment necessary? Spank JK Wrangler Technical Forum 10 01-14-2010 11:46 AM
TJ alignment and overall lifted vehicle "inspection"...where??? 06BlackRubicon TJ Wrangler Technical Forum 1 05-16-2009 01:37 PM
Just lifted... When to get an alignment? sailmike83 YJ Wrangler Technical Forum 13 02-11-2009 04:29 PM
just lifted, get alignment now or after tires? alecmcmahon TJ Wrangler Technical Forum 10 09-22-2008 04:09 PM
alignment novissahara TJ Wrangler Technical Forum 5 08-24-2004 10:54 PM
