Lifted a Rubicon? - JeepForum.com
post #1 of 12 Old 11-02-2003, 07:26 PM Thread Starter
bigusdadius
bigusdadius's Avatar
Lifted a Rubicon?
Has anyone lifted a Rubicon? I would like to hear what kit you went with and why.
I am planning on installing the Rubicon Express RE7000 4.5" Super-Flex Kit with a Tom Woods Rubicon CV and a set of Goodyear MT/Rs 305x70 R16. This is where I have a couple questions...
Do I need to replace both shafts?
To avoid lowering my T-case, will I need to lift my engine?
Am I missing anything?
Any info will be greatly appreciated! Thank you.
2003 Silver Rubicon
RE 3.5 on 33"MTR's w\JKS Discos
bigusdadius is offline
post #2 of 12 Old 11-02-2003, 09:17 PM
KaiserJeep
A lot of people have lifted Rubicons. The best way to clear those tires is the DPG "Deluxe TJ Kit" found here:
http://www.dpgoffroad.com/New_Folder3/OMEjeepprice.htm
...because it has about an inch less lift than the kit you want to use, doesn't require any new driveshafts, and rides better than stock, whereas the kit you want to use has more lift than required for those tires (dangerous) and rides very stiff.
Many run either 285/75R16 or 305/70R16 MT/R's with the above kit on Rubicons, both sizes are 33" diameter. The only difference is the 305's require another washer under the steering stops to prevent rubbing, and this causes the turning radius to be greater. If you don't care for this, you can spend another $500 on two pairs of 1.25" wheel spacers plus some Xenon fender flares.
Gary
1967 Kaiser Commando
2001 Grand Cherokee WJ
2003 Wrangler Rubicon TJ
KaiserJeep is offline
post #3 of 12 Old 11-03-2003, 07:06 AM
SlinkyTJ
This space for rent.
SlinkyTJ's Avatar
2009 JK Wrangler
Those tires will look a little small with that lift. You might consider the the 3.5 superflex. Here's my jeep with the 4.5 and 35's, before the body lift.
'09 JK
Lockers and stuff
SlinkyTJ is offline
post #4 of 12 Old 11-03-2003, 12:49 PM Thread Starter
bigusdadius
I was just showing my friend this picture! There are two reasons why I picked the 4.5...first I was worried about room for flex and second I can't afford to get 15 inch rims and tires now...maybe the 315/75 R16s?
2003 Silver Rubicon
post #5 of 12 Old 11-03-2003, 05:37 PM
SlinkyTJ
SlinkyTJ's Avatar
2009 JK Wrangler
To run 33in or bigger tires on those rims you'll need spacers to keep from rubbing when you turn, especially if you go with the wider tires. And those spacers are more expensive than the wheels I got. It worked for me since I just wanted cheap wheels anyway.
'09 JK
Lockers and stuff
SlinkyTJ is offline
post #6 of 12 Old 11-04-2003, 07:59 AM Thread Starter
bigusdadius
So, are you saying if I choose to run my current rims with tires larger than 33" I have to buy two pairs of 1.25" wheel spacers?
If so, I may consider spending the money on differnet rims and tires...but I really like the look of the stock rims...damn.
2003 Silver Rubicon
post #7 of 12 Old 11-04-2003, 06:32 PM
SlinkyTJ
SlinkyTJ's Avatar
2009 JK Wrangler
Sorry man, but that's the case. I really liked the stock wheels too, but I just sold mine. I couldn't really use them without spacers and thought i'd rather spend the money else where. Bright side is you can get a decent price for the stock wheels.
'09 JK
Lockers and stuff
SlinkyTJ is offline
post #8 of 12 Old 11-04-2003, 06:46 PM Thread Starter
bigusdadius
Thanks for the advice.
2003 Silver Rubicon
post #9 of 12 Old 11-04-2003, 08:28 PM
KaiserJeep
Make a deliberate choice, you could go either way. I intend to keep my Rubicon rims as well - I like 'em too.
It's true you could buy some cheap steel wheels for what the two pairs of spacers cost. ($125/pair at 4x4GroupBuy.com) If you can sell the MT/R tires and Moab wheels new, you can then get some decent forged wheels. But this means you need everything - lift, driveshafts, tires, gears, and wheels all at once - $$$$.
The real deal with spacers - or with new wheels with less backspacing - is how WIDE do you want to go, not how tall. Then think about if you need the small turning radius offroad (a stock Rubicon will turn tight enough to embarass a Honda or other small car).
My choice is the 305's and wheel spacers and flares. My Rubicon is a daily driver and I'm fond of really long trails like the Dusy, so I'm not willing to stress the Dana 44's with larger diameter tires and break up to 20 miles from help. Nor am I willing to lift it almost 4" without going about the same amount wider for road handling and to maintain the turning radius.
The other price plateau to think about is that above 33" in diameter you need new axle gears and a longarm lift. That's a significant chunk of cash and you are likely to have more hassles with warranty service than with more moderately-sized tires. If you've never owned a Jeep locked fore-and-aft with a 4:1 low range, then larger tires probably represent more than they are worth to you - unless you just like the way they look. Me, I care about if the Jeep gets me where I want to go and back again, and to work without breaking.
Gary
post #10 of 12 Old 11-05-2003, 06:02 AM
DarkRubiTJ
I'm running a 4" Skyjacker lift with 33x12.50 Xterrains on 15x12 Weld Classics. I,too, wanted to keep my Moabs but went with the Welds because they are forged and I wanted a wider track. I have no rubbing problems and street stability is top notch. I'm running stock gearing (4:11) and have no problems with acceleration or offraod performance. It's a good setup and I'm pleased.
DarkRubiTJ is offline
post #11 of 12 Old 11-05-2003, 04:30 PM Thread Starter
bigusdadius
Thanks!
Thanks for the feedback, it helps quite a bit.
I would like to stick with the Moabs and go with the MTR 305's. Here lies the issue...I am receiving conflicting information. I have a guy on another forum telling me he has the RE 4.5 with the 305s and no spacers, he goes on to state he has no rub on or off road. I definately want to retain the turning radius so I have a lot of research to do before I start ordering parts.
I am not prepared yet to go with a long arm kit...maybe in about 5 years when it's an off-road rig only and not my daily driver.
Thanks again for the info.
2003 Silver Rubicon
post #12 of 12 Old 11-05-2003, 09:08 PM
Uhdinator
I went with 2.5" OME HD springs and shocks with stock rims and 255/85-16's. Tires are about 32.5" tall and did not use a TCase drop or have any vibes. Consider 33x10 and you should be okay with stock rims. I have no body lift either. OME HD will give you more than 2". The LT or MED duty springs will only give you about 2". I have a hard top and Auto and the ride is not any worse than stock. Going with 255/85 is also load range D vice stiffer E rating of the stock MTRs. This softens the ride a hair too. E rating tires are usually used on bigger trucks due to heavy load capacity of big trucks which are overkill for a light jeep and contribute to the stiffer ride.
03 TJ Rubicon
2.5 OME HD
Auto, Hardtop
JKS disco's
Uhdinator is offline
Lifted rubicon driveshaft options Ulumanati TJ Wrangler Technical Forum 22 04-14-2010 04:28 AM
06 Rubicon - Is it lifted any? etgunner Wrangler General Discussion 9 07-18-2008 05:06 PM
New lifted Rubicon vibrations... rmontgomery2006 TJ Wrangler Technical Forum 8 03-31-2007 11:23 PM
Rubicon lifted? franco802 TJ Wrangler Technical Forum 10 11-13-2003 07:22 PM
