lifted jeep consistently pulls right, caster? - Page 3 - JeepForum.com
View Poll Results: your favorite rock sliders
a to z 0 0%
savvy 0 0%
rokmen 0 0%
metalcloak 1 100.00%
Voters: 1. You may not vote on this poll
post #31 of 40 Old 05-25-2013, 03:28 PM
biffgnar
biffgnar's Avatar
Originally Posted by rchase559
That wouldn't help any when the caster is 3 degrees different from one side to the other...
If I made the arms on one side longer or shorter the caster on that side wouldn't be different?
Romney in 2020!
biffgnar is online now
post #32 of 40 Old 05-25-2013, 04:05 PM
rchase559
Do your axle tubes spin in the housing?
rchase559 is offline
post #33 of 40 Old 05-25-2013, 04:26 PM
biffgnar
biffgnar's Avatar
Instead of thinking in terms of caster how about thinking about whether axle is square? If arms on one side are longer than the other, either because set that way or more likely because bent, what would happen? Might it pull significantly to one side just like OP describes? All sort of the same thing no?
Romney in 2020!
post #34 of 40 Old 05-25-2013, 04:48 PM
rchase559
You could point the axle in the opposite direction of the pull I guess. That seems like a hack fix for a caster issue though IMO.
I was only pointing out that caster is not independently adjustable from one side to the other with a set of adjustable arms. No more no less.
post #35 of 40 Old 05-25-2013, 06:18 PM
MLaborde
Tire air pressure?
MLaborde is offline
post #36 of 40 Old 05-25-2013, 09:32 PM Thread Starter
Cravenburrito22
All are set at 28
Cravenburrito22 is offline
post #37 of 40 Old 05-25-2013, 09:41 PM
BLK00TJ
He must have one of those new hi-tech axles that allow the tube to twist. Maybe his front axle was made on a Monday or a Friday and the inners were welded on all jacked up.
BLK00TJ is offline
post #38 of 40 Old 05-26-2013, 07:58 AM
MJBinNM
There are only a couple things I can think of that could cause your caster to be off that much from side to side. Bad ball joints or bent axle housing/knuckle.
You must have grown up in the no winners no losers generation where everyone gets a participation trophy and a pat on the butt for just showing up with their clothes on right side out.
MJBinNM is offline
post #39 of 40 Old 05-26-2013, 09:38 AM Thread Starter
Cravenburrito22
I jacked the wheels up and the shook the tires from top to bottom. The right had a small amount of play and the left had none
post #40 of 40 Old 06-04-2013, 12:33 PM
Nadamamasboy
If your Jeep's been in an accident or some incident where the axle took a hit at the hub end then you could very well have different caster on one side. This would need to be repaired carefully by a knowledgeable shop. There is no simple adjustment that can be made if this is your problem; and expensive control arms won't help either.
Tighten it 'till it strips then back it off a quarter turn
Nadamamasboy is offline
alignment , caster , lca , pulling , tj
