Lifted Jeep Caster Specifications - JeepForum.com
post #1 of 3 Old 05-01-2012, 09:20 PM Thread Starter
Scala37
Does anybody know the caster specifications for a wrangler lifted with a two inch BB? I want to change the specs to avoid getting death wobble. Thanks
Jeep
Scala37 is offline
post #2 of 3 Old 05-01-2012, 10:11 PM
ytowntj
If a lack of caster induces DW you have components that were worn about 1% away from having DW anyway.
Id shoot for about 5.5-6 degrees for 2". Im at 5.5 degrees at 2.5" andshe drives like butter.
Are you having issues with DW already or just trying to prevent it?
Parting my TJ:
My build - Odd approach to 33's
ytowntj is offline
post #3 of 3 Old 05-01-2012, 10:31 PM
2006_Sport
Caster won't cause DW. Well, I mean if it's excessive and your components are close to ****ting the bed, MAYBE.
You have a budget boost, you are fine.
2006_Sport is offline
caster degrees , caster setting , caster specification , death wobble , Specifications
specifications losfreddy TJ Wrangler Technical Forum 6 09-20-2015 03:43 PM
I6 4.0 specifications toberste TJ Wrangler Technical Forum 4 04-11-2009 10:06 PM
Spring specifications BASHOdi TJ Wrangler Technical Forum 0 02-14-2008 03:49 PM
Stock TJ Specifications Wheelin98TJ TJ Wrangler Technical Forum 10 08-24-2007 10:41 PM
FAQ - Dana 30, 35, and 44 specifications Wheelin98TJ TJ Wrangler Technical Forum 2 01-25-2007 02:47 PM
