Lift vs. Wheel Spacers Question - JeepForum.com
post #1 of 7 Old 03-20-2013, 08:51 AM Thread Starter
OurTJ
My sons and I are starting a 97 TJ project. It is 100% stock, low-ish miles, and has some rust issues. We will do the interior in Herculiner, paint the exterior, and de-rust the underside.
The stock steelies on it are very heavily rusted and the tires are worn-out. So, I bought some larger (not huge) TJ stock alloy wheels and tires from craigslist. At the max turn limits, the new wheels rub the suspension on the front. I probably should have done some backspacing research but didn't. I'll solve this with either a lift or spacers.
Every fastner/bolt on this thing has been a real challenge despite PB blaster, elbow grease and a torch. While fun and good learning for the boys, 10 minute projects turn into hour long battles. I am considering not doing a lift as we are not going off road with it.
Will 1.5" wheel spacers change regular road driving handling?
Am I being overly concerned about rust issues with doing a suspension lift?
We are looking at a 3 inch lift with a transfercase drop. We have the tools and capabilities to do it if it was not rusted.
Thanks for the advice.
OurTJ is offline
post #2 of 7 Old 03-20-2013, 08:57 AM
Ironhead
how big are the tires? what rims? You may be able to add a washer to your steering stops and solve the problem in ten minutes
I feel your pain with the rust and frozen bolts. its just something to work through. soak in PB blaster everyday for a week before a project. and a torch is a great way to loosen up bolts
Ironhead is offline
post #3 of 7 Old 03-20-2013, 09:01 AM
TheBoogieman
Devil's Advocate
TheBoogieman's Avatar
It should handle better with wheel spacers because of the wider stance.If it only rubs at full turn,you can add a couple washers to the steering stops instead of buying spacers.I just put some RC spacers on my XJ and had them on my 03' TJ.
http://www.stu-offroad.com/steering/...teerstop-1.htm
Originally Posted by jeepinmichguy_ View Post
TheBoogieman is a jerk.
Why also would he need a rare as hen's teeth Dana 44 out of another TJ which will eventually lead to him swapping in a POS 8.8 because he can't find one?
TheBoogieman is offline
post #4 of 7 Old 03-20-2013, 09:05 AM Thread Starter
OurTJ
Ironhead,
The tires are 31x10.5 R15s. So not that big vs. the 215 75 R15s I took off.
I like the ten minute solution on the steering stops since it is just barely touching, I'll look into that.
And just since we are new at this, by torch I mean my little propane torch. When guys say put a torch to it, are they talking about something else?
OurTJ is offline
post #5 of 7 Old 03-20-2013, 09:08 AM Thread Starter
OurTJ
Boogieman,
Thanks for the link. Will just regular old hardware store washers be fine or is there some special type?
OurTJ is offline
post #6 of 7 Old 03-20-2013, 09:15 AM
TheBoogieman
Devil's Advocate
Originally Posted by OurTJ View Post
Boogieman,
Plain old washers.
post #7 of 7 Old 03-20-2013, 09:19 AM
Ironhead
yep, the standard blue propane torch. doesnt get too hot to do a lot of damage, but hot enough to loosen up frozen bolts and soften up thread locker in the few places the factory put it
Ironhead is offline
lifts , rust , spacers
