Lift, tire, bumpstop, and other questions - JeepForum.com
post #1 of 9 Old 11-04-2013, 09:59 PM Thread Starter
Tylerl217
His is my first jeep and really first time working on cars. I am putting a 2.5 inch rc lift. And I have 33/12.50 tires coming in. Will I be able to run that with just driving 2 miles to work and back until I can put a 1 in bl on it? Will that work? And I plan on replacing the rc shocks with some bilsteins late on. Will I have to do a transfer case drop and or a mml? Like I said I'm new and any and all help would be appreciated. My off-roading will be pretty easy going with just some mudding/trail riding no rocks. I have an 03 tj.
Tylerl217 is offline
post #2 of 9 Old 11-04-2013, 10:42 PM
_KONG_
Yes. I would do the mml and body lift at the same time you do the lift
_KONG_ is offline
post #3 of 9 Old 11-04-2013, 11:34 PM Thread Starter
Tylerl217
I can't do those this weekend that's why I was asking if I could do those later
post #4 of 9 Old 11-05-2013, 03:20 AM
thedaringmove
You will probably be okay to lift it and not put a mml in right away. You may get slight vibes. You will definitely need to address the driveline angle though sooner than later. And like everyone else, i recommend a MML first, and then you cant drop the transfercase with washers if needed.
If you are getting some unbearable vibes when you first install the lift just use stacks of washers to lower your transfer case skid far enough so the vibes go away. Then you can drive until you get a MML installed. But DONT leave it with just the washers long term.
As for tire clearance with the 2.5" lift. Youll be fine just dont turn too hard (thats when they will rub)
thedaringmove is offline
post #5 of 9 Old 11-05-2013, 03:27 AM Thread Starter
Tylerl217
Originally Posted by thedaringmove
You will probably be okay to lift it and not put a mml in right away. You may get slight vibes. You will definitely need to address the driveline angle though sooner than later. And like everyone else, i recommend a MML first, and then you cant drop the transfercase with washers if needed. If you are getting some unbearable vibes when you first install the lift just use stacks of washers to lower your transfer case skid far enough so the vibes go away. Then you can drive until you get a MML installed. But DONT leave it with just the washers long term. As for tire clearance with the 2.5" lift. Youll be fine just dont turn too hard (thats when they will rub)
I plan on doing a 1" bl and the mml will anything else need to be done?
post #6 of 9 Old 11-05-2013, 03:47 AM
thedaringmove
I plan on doing a 1" bl and the mml will anything else need to be done? Sent from my iPhone using JeepForum
Its possible. I have just a slight shimmy at 50 mph with my MML and BL and im lifted 2" suspension. You will probably need a few washers (2 or 3 or each of the 6 bolts) to lower the transfercase skid since your doing a 2.5" lift. Then youll be all good. Its really not that much trouble to do this. Itll take you 20 mins max.
Google diy transfercase drop jeep tj or something. Theres a website called 4x4explorer or something like that (always forget the name) with a write up if you need it.
post #7 of 9 Old 11-05-2013, 07:34 AM
tyvanwie
I'd do it the other way around. Body lift and motor mount lift first, then do the suspension and tires later. If you don't have a big jack, you should really do the body lift first anyway.
tyvanwie is offline
post #8 of 9 Old 11-05-2013, 08:01 AM
-jb-
You can run the 2.5 lift with no problems. Will clear your 33's and you'll have no vibes. I ran a 2in lift on 33's for awhile when I first got my Jeep
You can do the bodylift later on. It's easy to do.
Yellow Jeep Member #42
01 TJ Sport
00 TJ Sport
-jb- is offline
post #9 of 9 Old 11-05-2013, 01:44 PM Thread Starter
Tylerl217
Originally Posted by -jb-
You can run the 2.5 lift with no problems. Will clear your 33's and you'll have no vibes. I ran a 2in lift on 33's for awhile when I first got my Jeep You can do the bodylift later on. It's easy to do.
Thank you jb
