Lift for this size????? - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > TJ Wrangler Technical Forum > Lift for this size?????
Introducing MONSTALINER™ UV Permanent DIY Roll On Bed LineRaceline/Allied Wheels on Sale NOW !Bead Lock Wheels! Raceline, Trail Ready, & Trail-Gear
Unread 06-25-2007, 11:20 AM   #1
2pac
I would like to buy tire size 275/80/15
How many inches should I lift? do I need to lower the double.
my rim width is 8''
_____________________________________________
2pac said:
"Don’t believe any think you read"
Jeep Wrangler 2005 orange 6 speed
2pac is offline   Reply With Quote
Unread 06-25-2007, 11:22 AM   #2
jeeptillidie
Depends on backspacing. You dont have to have any lift to fit it but it will work much better offroad with about 2" of lift. You should also make sure you have enough backspacing for that width of tire. About 4 1/2" is perfect.
jeeptillidie is offline   Reply With Quote
Unread 06-25-2007, 11:51 AM   #3
aszalan
275/80-15 appears to be a 32.3" tire so a 3" lift should be fine
aszalan is offline   Reply With Quote
