Lift Recommendation - JeepForum.com
post #1 of 3 Old 04-09-2007, 10:27 AM Thread Starter
spurrimj
Lift Recommendation
I just got new 33 12.50 r15 BFG AT's on my Jeep and I want to get a 4.5" lift. Any good recommendations for a nice lift but not to expensive. It's still going to be a daily driver so I don't want to go to crazy. Let me know what you guys think. Thanks
4" Rough Country/1" BL
SYE Kit/CV Drive Shaft
33 12.50 BFG AT KO's
Flowmaster exhaust / K&N Intake system
4.0 Throttle Body / Throttle body spacer
Custom rock crawling body damge
spurrimj is offline
post #2 of 3 Old 04-09-2007, 10:36 AM
ChrisMan
Get a 1.25" BL, 1" MML and 2" REBB, then your all set for about $600
ChrisMan is offline
post #3 of 3 Old 04-09-2007, 10:58 AM
Wheelin98TJ
JEEP FREAK
Wheelin98TJ's Avatar
Stick with 3" or less suspension lift if you want to keep the cost down.
Anything much higher and you'll need an SYE, driveshaft, and adj upper control arms which will add to the cost significantly.
Wheelin98TJ is offline
3" Lift Recommendation Requested hypractv JK Wrangler Technical Forum 7 08-24-2009 12:57 PM
Lift Kit Recommendation idahofreedom TJ Wrangler Technical Forum 6 04-14-2009 11:38 AM
Lift and Shop Recommendation Needed T's '97TJ TJ Wrangler Technical Forum 11 01-18-2009 01:52 PM
Budget Lift Recommendation Achillius TJ Wrangler Technical Forum 6 01-16-2008 10:29 PM
AX 5 and AX 15 Oil DC recommendation CKPA TJ Wrangler Technical Forum 1 04-27-2006 07:28 AM
