lift questions - JeepForum.com
post #1 of 14 Old 03-25-2010, 07:00 PM Thread Starter
RainingThunder6
lift questions
im looking at an OME 2.5" lift. what other things would i need? it comes with a t-case drop. but anything else i need? any help is awesome
RainingThunder6 is offline
post #2 of 14 Old 03-26-2010, 07:39 PM
Katch
Nothing else needed with the OME; however, consider what I did with my '02 Sport.
Instead of the t-case drop, I added a 1" motor mount and body lift. That will angle the drive shaft slightly alleviating the need for the t-case drop. Also, you won't have to relocate the radiator/fan as with body lifts alone, since the motor mount lift is installed-not to mention the extra inch of lift. I've probably put 40-50k miles on it since the install. Not a single issue.
BTW: Since I totaled my '02 a little over a year ago, I bought an '05 Rubicon. I plan to do that same setup. If I can motivate myself tomorrow, I'll install the motor mount/body lift. In a few weeks, I'll pick up the OME lift.
Steve
Katch is offline
post #3 of 14 Old 03-26-2010, 08:34 PM
Unlimited04
This post/info=my opinion
Unlimited04's Avatar
it doesn't come with cam bolts to correct caster, which you might want depending what your caster is now and ends up being after the lift. it also doesn't come with a front track bar or front bumpstops. you can redrill the front track bar mount, but make sure you weld a reinforcement plate over the existing stock bracket first.
Useful Write-Ups:
Fabrication & Build:
Funny:
Unlimited04 is offline
post #4 of 14 Old 03-26-2010, 08:37 PM
Katch
I didn't need those on my '02, but maybe I was just lucky.
Katch is offline
post #5 of 14 Old 03-26-2010, 08:37 PM
Unlimited04
or you don't know the difference.
Useful Write-Ups:
Funny:
post #6 of 14 Old 03-26-2010, 08:43 PM
Katch
What would the difference be? I installed the lift(s) about 7 years ago, and put over 40,000 miles with no problems. Whatever I did even corrected the death wobble I occasionally used to get.
I'm only asking since I plan to do the same lift with my '05 Rubi.
Steve
Katch is offline
post #7 of 14 Old 03-26-2010, 09:55 PM
Unlimited04
Steve
ok, so the factory caster spec is 7* +/- 1*. thats freakin' wide. After the lift my caster was 4*, way too low IMHO. Had persistent harmonic steering shimmy...not DW, but required two hands on the wheel and highway driving was scary. Overcorrection was far to easy and return to center sucked beyond my liking. Installed cam bolts, got to 5.5* caster - soooo much better driving overall. Will eventually get to 6-6.5* caster with adjustable arms and HPD30...should drive better than stock w/ OME suspension. But, rubidriver has a OME lift, and his caster is 5.5 with no cam bolts...and theres a Rubicon LJ on this forum with a long arm kit, and 1* difference in caster per side. The factory tolerance is so wide you won't know till the lift is on.
Now front bumpstops - 2.5" OME springs will compress fully into the stock spring tower, so you can run a max tire size of 31" unless you install a BL and/or some bumpstops. OME already includes rear 20mm bumpstops to clear the rear shocks & track bar relocation bracket. In fact, you really want to weld some reinforcement to the stock rear track bar bracket to reinforce the OME bracket...it puts a lot more leverage on there, causing it to rip off eventually.
Now the front track bar - the lift will cause the front axle to be off center by about 3/8-1/2" or so. this will cause you to rub the sway bar and control arms at lock on one side, depending on tire size and wheel backspacing. the ideal way to fix this is an adjustable track bar. problem is there is no adjustable track bar that works with less than 2" of front bumpstop because they all hit the front diff cover.
read here: http://www.jeepforum.com/forum/f9/tj...it-fit-738948/
ok, so to reuse the stock front track bar, you need to drill a new hole in the mount. This weakens the mount greatly. This means you need to weld a support to it.
Read here: http://www.jeepforum.com/forum/f9/br...racket-905624/
This is the case with any lift btw...not just the OME.
Useful Write-Ups:
Funny:
post #8 of 14 Old 03-26-2010, 10:12 PM Thread Starter
RainingThunder6
so what exactly would i need. and what is a caster?
post #9 of 14 Old 03-26-2010, 10:17 PM
Unlimited04
read about caster here: http://www.jeepforum.com/forum/f9/en...g-read-663777/
everything else i already outlined above, read the links.....
the OME is very good quality stuff...but there is just no full complete "kit", no matter what brand we're talking about....
Useful Write-Ups:
Funny:
post #10 of 14 Old 03-26-2010, 10:22 PM Thread Starter
RainingThunder6
but for starters could i just do the suspension t-case drop and rear track bar relocation? because i don't really want to do the motor lift and body lift.
post #11 of 14 Old 03-26-2010, 10:27 PM
Unlimited04
definitely, as long as you can tolerate rubbing 31x10.50" wide tires on the control arm on the passenger side (or you could change backspacing or steering stops). just be aware of the issues described above, especially the rear track bar bracket tendency to rip off.
Useful Write-Ups:
Funny:
post #12 of 14 Old 03-27-2010, 02:12 PM Thread Starter
RainingThunder6
maybe a front trackbar..
post #13 of 14 Old 03-27-2010, 03:09 PM
Jeepzcb09
you dont have to do a body lift with a MML, you can do one by itself or together, its just a good combo
1998 TJ Sport : Rough Country, MetalCloak,KC, Goodyear, Crager, Alpine, AtoZ, Currie, Aussie
Believe.
Jeepzcb09 is offline
post #14 of 14 Old 03-29-2010, 10:03 AM Thread Starter
RainingThunder6
any other recommendations for lift kits other then OME?
lift , ome , questions
Body lift, Motor mount lift questions Hoofguy TJ Wrangler Technical Forum 15 07-06-2012 05:22 PM
Body Lift and Motor mount lift questions RYANR97 TJ Wrangler Technical Forum 12 08-31-2008 01:31 PM
Lift Questions - E-brake bracket + Pics of the lift so far! tommanns YJ Wrangler Technical Forum 7 07-26-2008 12:06 AM
Questions regarding Body Lift and Motor mount lift ToddEdge TJ Wrangler Technical Forum 5 11-26-2007 12:52 PM
Suspension Lift, Body Lift Questions CityJeep TJ Wrangler Technical Forum 2 06-12-2005 03:52 PM
