Quantcast Lift Questions - Page 2 - JeepForum.com
Truck-Lite 7" Round Headlamp Giveaway! - Drive OffRoad Gift Certificate Contest!
Go Back JeepForum.com > Models > Jeep Wrangler Forums > TJ Wrangler Technical Forum > Lift Questions
Introducing MONSTALINER™ UV Permanent DIY Roll On Bed LineSwag Off Road BIG-HIT TJ-YJ Rear BumperNEW Fawkes modular recovery & bull bar mounts for WJs.
Unread 04-10-2009, 08:39 AM   #16
Wheelin98TJ
JEEP FREAK
Wheelin98TJ's Avatar
You can make a drop bracket for where the linkage attaches to the body if you cannot get the transfer case to shift right after adjusting the linkage.
Here is an example I drew up:
Wheelin98TJ is offline   Reply With Quote
Unread 04-10-2009, 09:50 AM   #17
Sheetz15
Junior Member
Sheetz15's Avatar
So how difficult is it to adjust the linkage. I mean the directions sound pretty simple, but when I'm under my jeep nothing ever goes as smooth as the directions show.
Sheetz15 is offline   Reply With Quote
Unread 04-10-2009, 03:03 PM   #18
Sheetz15
Junior Member
Sheetz15's Avatar
Ok so how exactly do i go about installing this drop bracket?
Unread 04-10-2009, 03:34 PM   #19
Wheelin98TJ
JEEP FREAK
You bolt the bracket to the tub.
Then the linkage bolts to the new, lower mounting holes on the bracket.
Unread 04-10-2009, 03:52 PM   #20
Sheetz15
Junior Member
Sheetz15's Avatar
well that sounds pretty simple. I guess i have a new project for this weekend. I love this site. Its great
