Lift Questions - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > TJ Wrangler Technical Forum > Lift Questions
CHASSIS SAVER™ Rust Preventive Paint Memorial Day Weekend RuffStuff Memorial Day Sale!Introducing MONSTALINER™ UV Permanent DIY Roll On Bed Line
Unread 02-09-2012, 04:57 PM   #1
FLaminTJ
Lift Questions
With 31" tires, what is a good size lift? I was thinking 2"-2.5" but I don't know what it would look like. Also, should I go with a spacer lift or coil lift? Yes Ive used the search tab to try and find something but to no avail. Any help would be nice. Also, I am going to stay with the 31"s for a while.
FLaminTJ is offline   Reply With Quote
Unread 02-09-2012, 05:43 PM   #2
jdub36
Most of us lift to fit a bigger tire. What are you hoping to gain from the lift if you are currently running 31's? If you are just wanting a little more clearance I would look at a budget boost. I ran one for a couple of years with 32x11.50 tires and it worked fine. I think with 31's if you put too much lift on it might look silly. Most guys running 33's only have 3 inches of lift.
Might help us give you a better answer if you explain what are you wanting/needing to get out of the lift and what your future plans are for the jeep.
jw
jdub36 is offline   Reply With Quote
Unread 02-09-2012, 06:54 PM   #3
boarderthug
With 31s you dont need a lift.
I ran mine that way for a good 5 years.. just bump out the steering stops so they dont rub at full lock
if you have saggy springs maybe a spacer lift.. or new stock springs.
also check out the "Sticky" what does my tj look like with _ lift?
its in the threads at the top of the tj technical forum that this thread is in.
boarderthug is offline   Reply With Quote
Unread 02-09-2012, 07:20 PM   #4
FLaminTJ
Eventually I am wanting to get larger tires but for now I don't have the money. Also I want to do some off roading and 31s with stock suspension doesn't allow much room to flex.
Unread 02-09-2012, 07:29 PM   #5
B3astyP3nquin
Look at a used tire place. I am going to get some new tires for 100 bucks each for 35' tires. Just a suggestion. The tires are brand new also.
B3astyP3nquin is offline   Reply With Quote
Unread 02-09-2012, 09:26 PM   #6
djflyy
Adventure Is Out There
djflyy's Avatar
For 31" tires with the desire to flex offroad, I'd point you in the direction of a 2.5" or 3" suspension lift. The 2.5 might be a better choice if you are not ready or looking to invest in potential SYE/driveshaft kits, adjustable control arms/track bars, etc. The 3" with 31" tires leaves what I personally thought was an awkward amount of space in the wheel wells, although I did run that way for a few years. Hated how it looked.
There are a few good options for the 2.5" range. Check out Old Man Emu and Rough Country. The RC 2.5 kit I believe has a good following, even from the more advanced group that never have a good thing to say about the company.
Boston Jeep Build Thread
North Shore Jeeps Website
Originally Posted by StuddMuffinz View Post
dj, it amazes me how your jeep can always make me happy in the pants <3
djflyy is offline   Reply With Quote
Unread 02-11-2012, 12:25 AM   #7
tjtrucker
here's mine with 32" tires and a 2.25" BBL kit, I've also got .75" Prothane Isolator pads in the front, giving me a total of 3" in front, 2.25 in back
tjtrucker is offline   Reply With Quote
31" tires , bb lift , lift help , lift kit , new guy
