Lift Question - JeepForum.com
post #1 of 9 Old 06-20-2011, 01:42 PM Thread Starter
mitch82
Lift Question
hey guys, i just put on 2in coil spacers on my tj and i love it but i want a bigger lift. How high can i go before i have to start messing with other stuff like the transfer case and brake lines and stuff? And what is a cheap way to do this, and add just alittle bit more? thanks
mitch82 is offline
post #2 of 9 Old 06-20-2011, 01:44 PM
TheBoogieman
Disturbed
TheBoogieman's Avatar
You're at the limit.Add a 1.25" BL for more lift without the headaches.
TheBoogieman is offline
post #3 of 9 Old 06-20-2011, 01:46 PM Thread Starter
mitch82
thanks man, what would i have to change if i added 2 more inchs with new coils?
mitch82 is offline
post #4 of 9 Old 06-20-2011, 01:55 PM
Richierich1105
x2 on the body lift and its really not noticeable unless you are looking for it..id suggest a mml while youre at it to keep from having to trim the fan shroud..i trimmed mine but it rubs the fan slightly when the body shifts/rolls around sharp turns and when flexed..i plan on doing one when i get the extra cash..also as far as lift goes, ive got a 2.5 lift and only had to shim the t-case skid about a half inch to eliminate vibes
97 tj 4banger with some junk slowly being upgraded
04 Ram DD
Build thread
Richierich1105 is offline
post #5 of 9 Old 06-20-2011, 02:02 PM Thread Starter
mitch82
nice, thanks, would i be able to pick something up at like home depot to make the spacers bigger, like a couple washers or something?
mitch82 is offline
post #6 of 9 Old 06-20-2011, 02:06 PM
TheBoogieman
Disturbed
Nope,you can buy a quality 1.25" BL with everything you need for around $100.If you try to make one it's a PITA to make grill supports,fan shroud relocation bracket and t case bracket.If you've never done one,you could still do it yourself in 2 hours with minimal tools.
post #7 of 9 Old 06-20-2011, 02:11 PM
Unlimited04
This post/info=my opinion
Unlimited04's Avatar
if you want a total of 4" of suspension lift, you'll need everything required for 4" of suspension lift. combining lift coils with 2" BB spacers is a bad idea due to something called coil bind. for this reason you get 4" lift coils.
in addition to new coils, you'll need new shocks, SYE/CV shaft, adjustable control arms, adjustable track bars, rear track bar relocation bracket, longer brake lines, longer sway bar links, upgraded steering, upgraded brakes and proper length bumpstop extensions.
Useful Write-Ups:
Fabrication & Build:
Funny:
Unlimited04 is offline
post #8 of 9 Old 06-20-2011, 02:19 PM
TheBoogieman
Disturbed
Your job is done with this.
post #9 of 9 Old 06-20-2011, 02:28 PM
Richierich1105
I did mine in my condo parking lot with nothing but a hi-lift and a socket set..Rokmen has a video on you tube that breaks it down real well..I would'nt recommend going to a 4" if you are trying to be inexpensive
04 Ram DD
Build thread
coil , jeep , lift , spacer
Tryin to figure out how I'm running 33's. Lift or body lift question. dm33buckeyes TJ Wrangler Technical Forum 21 08-14-2011 04:06 PM
Motor Mount lift / body lift question hanshunter YJ Wrangler Technical Forum 8 03-02-2011 06:59 AM
Stupid question. Anyone ever fab anything to lift rear bumper after doing 1" lift blackruby56 TJ Wrangler Technical Forum 11 09-11-2009 01:15 PM
body lift or suspension lift, no this isnt a stupid question!! lumpster TJ Wrangler Technical Forum 5 05-11-2009 09:19 PM
Kinda newb lift question-lift springs signal34 TJ Wrangler Technical Forum 2 08-05-2008 07:56 PM
