lift kits - JeepForum.com
post #1 of 6 Old 04-24-2009, 08:31 PM Thread Starter
rickieross
lift kits
i want a 4 inch lift off rough country its the 4" Series II Lift fallen price on sale lift is that all i need or do i have to get the 4" X-series Lift thats twice as much its for a 98 tj wrangler the 4" X-series Lift come with much more but the series II says its a complete kit
rickieross is offline
post #2 of 6 Old 04-24-2009, 08:37 PM
PurpleTJ
well first of all, punctuation is very very useful...
and second, not sure what your question is, due to lack of punctuation
PurpleTJ is offline
post #3 of 6 Old 04-24-2009, 09:38 PM
RubiconRazorbac
RubiconRazorbac's Avatar
What?????????
Your shaft isn't long enough to handle that kind of droop...
2003 TJ Rubicon:
2017 JKU Rubicon:
RubiconRazorbac is offline
post #4 of 6 Old 04-24-2009, 10:40 PM
N2SPD
I want a 4 inch lift. Rough Country has the 4" Series II Lift on sale. Is that all i need or do i have to get the 4" X-series Lift thats has twice as much. It is for a 98 tj wrangler. The 4" X-series Lift comes with much more but the series II says its a complete kit.
I think this might be what he is trying to say.
N2SPD is offline
post #5 of 6 Old 04-25-2009, 05:52 AM
RubiconRazorbac
There's a big reason the X-series costs more---all 8 control arms are adjustable. With the II series kit, you get four new lowers (no uppers), and they're fixed (although presumably a little longer than stock) rather than adjustable.
Do a search and read up on pinion angle, caster, and wheelbase adjustments and you'll see why it's worth the extra money to get the adjustable arms. Not to mention they're supposed to be significantly stronger than the stock arms.
2003 TJ Rubicon:
2017 JKU Rubicon:
post #6 of 6 Old 04-25-2009, 07:53 AM
RogueSpear2023
The X series lift is more than twice the lift of the series 2. The series 2 lift is not complete as much as they would like to say it is. If you want to go cheap I would look at the RC 2.5" lift or the 3.25" lift. Many here had put the series 2 in and realized they then have to fork out more cash for adjustable uppers and lowers. Plus with the X not only do you get adjustable lowers and uppers you sway bar disconnects. If you jeep is stock you are also going to have to look at an SYE and and a new drive shaft, with 4" of lift, where as with 2.5" if you did a 1.25" body lift and 1" motor mount lift you probably would not.
Max
2003 Jeep Wrangler Rubicon
4.0L, 42RLE, Dual Tops, Full Doors, JKS Front Disconnects, Cragar Soft 8 Black Wheels, 33x12.5x15 Goodyear Duratracs, .75" Front Coil Spacers, Bushwacker 6" Flat Fender Flares, Skid Row Steering Box Skid, LubeLockers, Rubicon Locker Mod, OBA, Cobra 19 Ultra III CB, 3' Firestik, Rough Country 2.2 Steering Stabilizer, RC 1.25" BL, RC 1" MML, RC Grab Handles, Fog Lamp Bent Pin Mod, 4" Apline S Series Speakers, Kenwood Excelon 6.5" Speakers, 6.5" JL Audio 6W3V3 Subwoofer (in center console) w/MTX Thunder 202 amp, IPF H4 Headlight Housing, Sliverstar H4 bulbs.
"Buying a jeep and not taking it off road, is like buying a dragster and never taking it to the track"
RogueSpear2023 is offline
Lift kits jwentworth TJ Wrangler Technical Forum 4 04-05-2009 06:48 PM
Question about lift kits and spacer kits. EvanQuinn TJ Wrangler Technical Forum 4 01-11-2009 05:21 PM
will my body lift affect future lift kits??? SouthernMoose TJ Wrangler Technical Forum 6 10-22-2006 08:34 PM
BDS Lift Kits Birdlaw TJ Wrangler Technical Forum 6 05-22-2004 08:58 AM
lift kits cruzjeeper TJ Wrangler Technical Forum 3 05-21-2004 07:47 PM
