lift kit, tires, wheels - JeepForum.com
post #1 of 4 Old 10-06-2010, 08:06 PM Thread Starter
Utfan010
if i were to buy a 3.25 RC lift kit, 1.25 spacers, and cragar soft 8 wheels with proper backspacing and new tires what shoud i buy first im thinking i should get the wheels first and the spacers
when in doubt, press the skinny pedal!
Utfan010 is offline
post #2 of 4 Old 10-06-2010, 08:10 PM
Mopar Fan
Why would you purchase wheel spacers when you are also purchasing wheels with "proper" backspacing?
Mopar Fan is offline
post #3 of 4 Old 10-06-2010, 08:18 PM Thread Starter
Utfan010
haha i cant believe i just put that. i wasnt even thinking about it
Utfan010 is offline
post #4 of 4 Old 10-07-2010, 12:05 AM
Demp
you can buy the wheels and have your old tires mounted to them, as you will more than likely need the lift on for bigger tires.
Lift will have to come before tires though, if that helps any. I'd personally put the lift on then get your new tires on the new wheels.
Demp is offline
lift kit , rough country , spacer , wheel
What wheels, tires, and lift should i get 04TJwranglerguy TJ Wrangler Technical Forum 30 12-13-2009 04:45 PM
Lift, wheels and tires on! blackTJosh TJ Wrangler Technical Forum 15 08-10-2009 09:39 AM
Lift, Wheels and Tires surfsup887 TJ Wrangler Technical Forum 11 06-21-2009 09:16 AM
Anyone have a pic of where to lift an '05 TJ? Have new tires/wheels Sia Bani TJ Wrangler Technical Forum 2 02-24-2008 11:02 AM
tires / wheels / lift? on a 2.4 sccabrian TJ Wrangler Technical Forum 3 04-09-2007 05:28 PM
