Lift kit thoughts? - Page 6 - JeepForum.com
post #76 of 214 Old 09-11-2013, 02:37 PM
PStov98TJ
Spacers will add more stress to the axle and maybe buy you 3" total.
As far as "long arm" versus "short arm", I'm a fan of keeping the arms on the shorter end. In my opinion, it's easier to keep better clearance underneath the jeep when you don't have arms hanging all over the place. And you have to keep in mind the idea of useable travel. If you have enough travel to unseat a spring, what good is that tire doing you that has no weight on it? My point here being that you can get all the useable travel you want out of a short or mid arm setup the same as you can by going with a long arm setup, only with more clearance.
98 TJ, 2.5" OME lift, 33x12.5 MTR's, MC trackbar, MC aluminum fenders and bumper, Warn XD9000i
PStov98TJ is offline
post #77 of 214 Old 09-11-2013, 03:01 PM
Kodiak17
Downsize your tires or upsize your axles... Or a combination of both: HP30 and 8.8 with chromo's can last on 37's.
Maintain, wheel, upgrade, repeat.
My build: http://www.jeepforum.com/forum/f22/thor-dd-weekend-warrior-1348534/
Kodiak17 is offline
post #78 of 214 Old 09-11-2013, 03:28 PM
JeepAddOnsChris
Vendor
JeepAddOnsChris's Avatar
I don't really agree with the idea of running 37s on a Dana 30. Even with a high pinion XJ upgrade, especially with this being a daily driver. For you to be happy with the performance on the street, you're going to need to run deep gears. The R&P of a D30 just isn't large enough to handle the shock loads associated with rock crawling on 37s.
Yes, I do run Black Mountain. I'll be back down for Fall Crawl.
If you want to go play at Harlan or similar areas and you want to go with the biggest tire size you can and still stay as a daily driver on the axles you're talking about, here would be my suggestion on the axle combo you're thinking about.
HPD30, chromo shafts, 4.10 gears. Ford 8.8 stock axles 4.10 gears is a good setup up to 35" tires. Granted, this is slightly underpowered on the road, but not bad with a 4.0. You are at a sweeter spot for deeper gearing than a stock 4.0 gears, but not toothpick thin like on a 4.88. 35" tires only require minor trimming.
LPD30 (what you have now on your TJ), chromo shafts, 4.56 gears and Super 35 kit (which I never recommend, but some people want them) or a stock 8.8 with matching gearset will be just fine for 33" tires.
There's not tons of obstacles in a place like Harlan for the guys on 33s. 35" tires can get you into and out of most of the fun places that the guys on 37s go (assuming you have some driving skill). Many places in that area require even bigger tires. I'm limited down there in what I can do on 38s. However, anything over 35s should always go hand in hand with axle swaps.
We are currently away from the forums and unavailable for quotes. Please contact our sales team at 800-388-8637.
Visit our site
Like us on Facebook
JeepAddOnsChris is offline
post #79 of 214 Old 09-11-2013, 03:30 PM
BamaJeepman21
Originally Posted by will1424 View Post
That's a lot of flex out of a short arm
Contrary to popular belief, short arms "flex" just as well as long arms. Joints have come a long way from some Poly flex joint crap to the latest and greatest Johnny Joint and Duroflex joint.
You know I posted this for help finding a kit. Well then I decided to build one. I'm asking for ideas and opinions on what I should do. If I wanted to hear someone run there mouth I would have just talked to my girlfriend instead. Either help me out (which I will very well appreciate) or shut your cock suckers. Simple as that A lot of people can run there mouth behind a keyboard but I doubt any of them will come out from behind it. Lol. And I'm not on here to start trouble like some people are. I'm asking for advice. Help or gtfo .
Godamnit man. You must be really trying to get banned. You're just another one of those people that think they're all tough outside of the computer and everyone else on the Internet isn't. You should try Pirate 4x4.
I for one, give zero ****s.
Originally Posted by Ripper3494 View Post
he just has a blunt way of saying things, you get used to it.
Isn't this the truth. It took me the longest time to figure this out.
-Jack
BamaJeepman21 is offline
post #80 of 214 Old 09-11-2013, 05:04 PM Thread Starter
will1424
Thanks to all of you for the advice. Does anyone have an idea of why my jeep screetches at around 3k rpm on the highway? I also have a noise from the front DS normally in cold weather or moist weather that sounds like birds chirping. When I go to 4wd it goes away? Any thoughts?
will1424 is offline
post #81 of 214 Old 09-11-2013, 05:13 PM
JeepAddOnsChris
Vendor
Driveshaft, likely u-joints. Could also be coming from the front axle u-joints.
The screeches are likely coming from your stock axles screaming in pain at the thought of running big tires and begging to be put out of their misery.
That could also come from the driveshaft or belt or a number of things like a pulley, alt, pump, etc. Pull the front driveshaft, take it for a drive and see what happens.
Visit our site
Like us on Facebook
post #82 of 214 Old 09-11-2013, 05:19 PM
Imped
Imped's Avatar
The screech is the belt or a pulley bearing.
The front drive shaft noise is your centering yoke ball dry in the socket. Replace it.
OlllllllO
IndyORV
Imped is offline
post #83 of 214 Old 09-11-2013, 05:26 PM Thread Starter
will1424
Well right now I'm just on 33s lol. I don't think its the axles. Thanks for the help
will1424 is offline
post #84 of 214 Old 09-11-2013, 05:27 PM Thread Starter
will1424
How would I troubleshoot the pulley etc.?
will1424 is offline
post #85 of 214 Old 09-11-2013, 05:29 PM
biffgnar
biffgnar's Avatar
Have somebody rev up the motor while you look under the hood. Take a real long screwdriver and carefully put the blade end against each pulley. Put your ear to the end of the screwdriver. Should be pretty clear which one is making the noise.
Romney in 2020!
biffgnar is offline
post #86 of 214 Old 09-11-2013, 05:36 PM Thread Starter
will1424
Good deal. Thanks a bunch
will1424 is offline
post #87 of 214 Old 09-11-2013, 05:50 PM
Necko2529
You should've used a disclaimer with this statement. I doubt he's bright enough, at 19, to do this without being taken for a bad ride or possibly killing himself.
Rokmen TT, Rokmen control arms, Novak NV241 cable shifter, JKS 1.25" BL + 1" MML.
Anybody can take advice if it doesn't interfere with their plan.
RIP "Prescott 19" Prescott Fire Department
Necko2529 is offline
post #88 of 214 Old 09-11-2013, 06:13 PM Thread Starter
will1424
Why does everyone insist on running their mouth. Yes i am capable of doing it. I promise you. I've been on construction sites since I was 15. Worked on plenty of cars. I can run hvac all through your house. As well as water lines. I can handle troubleshooting that. I'm sure there are plenty of things I can learn from you. But even though I'm 19 I'm sure there are plenty of things you could learn from me. I'm tired of arguing with everyone. Age is not a factor in this. Its work knowledge.
will1424 is offline
post #89 of 214 Old 09-11-2013, 06:14 PM
Unlimited04
This post/info=my opinion
Unlimited04's Avatar
I disagree with the shock to CA angle . Standard is in the ballpark of 90 degrees and in one of the pictures it looks more around 60. The coil buckets being moved back could make contact with the shocks. Maybe not. Overall i like the idea especially since thats just with 2.5" lift springs. The CA angle just bothers me because rule in hand is that the more level the angle the smoother the ride. witch that could always be fixed by adjusting the CAs and moving the frame mount slightly forward.
You missed every aspect I was asking about and focused on something of minor consequence. There's a whole lot more going on in those pics besides control arm vs shock angle....
You did however prove you don't have the working knowledge to attempt a build on the scale you're proposing. I just hope you realize that, swallow your pride and start trying to learn from the teachers you're arguing with.
Useful Write-Ups:
Fabrication & Build:
Funny:
Unlimited04 is offline
post #90 of 214 Old 09-11-2013, 06:16 PM Thread Starter
will1424
You did however prove you have a lot more reading and learning to do before even think about attempting a build on the scale you're proposing.
Then tell me what you wanted me to tell u and ill tell u how I would fix it.
will1424 is offline
jeep , lift , long arm , tj
