Lift Kit Recommendation - JeepForum.com
post #1 of 7 Old 04-14-2009, 10:17 AM Thread Starter
idahofreedom
I have a 2005 Rubicon Unlimited and would like to install a 3" suspension lift kit.
Does the Rubicon Unlimited need a special lift kit?
What is different in a lift kit for a Rubicon?
What is different in a lift kit for an Unlimited?
The Rubicons already seem higher than the standard model, so if I order a 3" kit, will I get a full 3" of lift? If the Rubicon already has taller springs, I was thinking new springs would not be a full 3" taller.
Thanks for any help,
Mark (newbie)
idahofreedom is offline
post #2 of 7 Old 04-14-2009, 10:23 AM
mdm
Farm Wheeler
Originally Posted by idahofreedom View Post
...Does the Rubicon Unlimited need a special lift kit?...
No
...What is different in a lift kit for a Rubicon?...
Nothing
...What is different in a lift kit for an Unlimited?...
Nothing
...The Rubicons already seem higher than the standard model...
It's not higher because of the suspension, it has bigger tires than other models.
One thing to keep in mind is that lift kits do not give you exactly the advertised lift. It all depends on the Jeep and how it is loaded; winch, armor, cargo, hard/soft/no top,... Most kits will actually give you a little more than the advertised height.
Keep in mind that free advice can frequently be worth less than you pay for it.
mdm is offline
post #3 of 7 Old 04-14-2009, 10:41 AM
03rubicon35s
Mark (newbie)
the only reason you would need a special kind of lift is if you go with a longarm kit.. for that obviously you would need a different kit from a regular wrangler because of the long rear end..
03rubicon35s is offline
post #4 of 7 Old 04-14-2009, 11:28 AM
TheBoogieman
Disturbed
TheBoogieman's Avatar
Nadda,Niltch,No ting deeferent.
TheBoogieman is offline
post #5 of 7 Old 04-14-2009, 11:30 AM
hyperboarder
1992 XJ Cherokee
I think you should just forego the trouble and trade me straight up .
hyperboarder is offline
post #6 of 7 Old 04-14-2009, 11:32 AM
BriansCJ
1994 XJ Cherokee
Not unless you go long arm
Nothing
Nothing unless you go long arms
Rubicon springs are not taller. They have a higher spring rate. You should still get 3" of lift. The 31" MT/Rs make it look taller
Mark (newbie)
YEA...................
- Daily Driver & Weekend Wheeler
- Slow
BriansCJ is offline
post #7 of 7 Old 04-14-2009, 11:38 AM
c.a. jones
c.a. jones is offline
3" Lift Recommendation Requested hypractv JK Wrangler Technical Forum 7 08-24-2009 12:57 PM
Lift and Shop Recommendation Needed T's '97TJ TJ Wrangler Technical Forum 11 01-18-2009 01:52 PM
Need recommendation Mamas Jeep YJ Wrangler Technical Forum 10 04-02-2008 01:58 PM
Budget Lift Recommendation Achillius TJ Wrangler Technical Forum 6 01-16-2008 10:29 PM
Lift Recommendation spurrimj TJ Wrangler Technical Forum 2 04-09-2007 10:58 AM
