Lift Kit Questions - Page 2 - JeepForum.com
post #16 of 43 Old 08-28-2013, 10:02 PM Thread Starter
BABrax
Originally Posted by BamaJeepman21 View Post
I'm just going to say that good and inexpensive *can* be in the same category...just hear me out.
RC 2.5" coils (only good thing RC makes)- $199
Skyjacker Hydro's- $150
JKS 1.25" body lift- $90
JKS 1" MML- $70
RC quick disco's- $70
Right there you have the ability to run 33's and you're not screwing anything up. If it were me though, I would change the shocks out to some Bilstein 5100's but they run around $300. Anyway for $580 you can have something that does 90% of what you want, ride pretty good, and overall not **** anything else up. I REALLY wish people would do research like this. From there you can add trackbars, new control arms, tummy tuck...etc.
This is my research! picking your guys minds!
BABrax is offline
post #17 of 43 Old 08-28-2013, 10:11 PM Thread Starter
BABrax
Originally Posted by s62e39 View Post
Is there a brand listed on the shocks? Does it have a lowering front track bar bracket? New track bar? Second hole drilled in the bracket to center the axle?
Does it have tubular lower control arms? Post some pics
Front left coil
Rear side of left coil with control arm
Right coil
Rear Coil left side
As you can see, rancho shocks, big coils, any other info you can shed would be nice
BABrax is offline
post #18 of 43 Old 08-29-2013, 06:53 AM
tyvanwie
Doesn't look like you have a body lift.
tyvanwie is offline
post #19 of 43 Old 08-29-2013, 07:09 AM
s62e39
Agreed, no body lift. Stock control arms. Quick disconnect sway bar links. Can't see the track bar from your pics. If I was a guessing man I'd say 2.5-3.5" lift. Like we said, make some measurements.
s62e39 is offline
post #20 of 43 Old 08-29-2013, 07:13 AM
s62e39
And looks like your front right tie rod ball joint boot is torn. Bump stops don't seem to be extended much... Hard to say a lot about your setup by just looking at cellphone pics
s62e39 is offline
post #21 of 43 Old 08-29-2013, 07:15 AM
Unlimited04
This post/info=my opinion
Unlimited04's Avatar
they appear to be extended a whole bunch to me. look closely, appears to be 3" body pucks, or larger, in front and rear on the bumpstop towers.
Useful Write-Ups:
Fabrication & Build:
Funny:
Unlimited04 is offline
post #22 of 43 Old 08-29-2013, 07:27 AM
s62e39
I guess you're right. Exactly the opposite. Forgot where they're supposed to be
s62e39 is offline
post #23 of 43 Old 08-29-2013, 08:35 AM Thread Starter
BABrax
So that suggesting i have about a 3 inch lift?
Im a college student so ill have to get my hands on a tape measure and let you guy know the measurements
BABrax is offline
post #24 of 43 Old 08-29-2013, 08:37 AM
Unlimited04
not at all.
Useful Write-Ups:
Funny:
post #25 of 43 Old 08-29-2013, 08:38 AM Thread Starter
BABrax
Yeah i dont think i do either, just the stock rubber spacers. I think im going to add a 1-2" body lift soon
BABrax is offline
post #26 of 43 Old 08-29-2013, 08:40 AM Thread Starter
BABrax
not at all.
Than what's it suggest?
BABrax is offline
post #27 of 43 Old 08-29-2013, 08:47 AM
Unlimited04
it merely suggests somebody extended the bumpstops a whole bunch at one point.
it's also worth noting you have an RE, or similar, diff bashing front track bar. the only thing keeping the track bar from bashing your diff are those huge bumpstop extensions...(or the shocks bottoming out, which is also bad).
Useful Write-Ups:
Funny:
post #28 of 43 Old 08-29-2013, 10:13 AM
rda616
Anything over 1.25" can be problematic, is ugly and isn't advised.
rda616 is offline
post #29 of 43 Old 08-29-2013, 11:41 AM
Clarke2k
Clarke2k's Avatar
I m going to say take some measurements, If you have stock fenders measure from them to the center of your hub. Stock front should be 17.5" and 19" in the rear. These measurements can be manipulated by spring sag and aftermarket bumpers and winch. Body lift is easy to see because you will have a gap between the frame and tub. Look for spacers on top of the coils and as for as lifts there are many threads you can read. Keep in mind you get what you pay for. I like my cheap lift but I will upgrade to adjustable shocks to fine tune my jeep.
Clarke2k is offline
post #30 of 43 Old 08-29-2013, 07:24 PM Thread Starter
BABrax
RE? Diff bashing front track bar? Not sure I follow can you elaborate?
BABrax is offline
jeep tj , lift advice , lift kit , lift kit advice , skyjacker
