lift kit install problems... - JeepForum.com
post #1 of 7 Old 02-23-2008, 01:43 PM Thread Starter
jmkeo74
6 to 8 hours is what RC says in the instructions...HA! I must have the most difficult 97 TJ in the world. Every nut I've turned has either broken off or stripped out. Anyone have tips on how to remove a stripped T-50 Torx head? Any other general tips will be greatly appreciated...
jmkeo74 is offline
post #2 of 7 Old 02-23-2008, 01:47 PM
CrackerJim
Sounds like a job for an easyout.
Did you use penetrating oil the day before on the bolts?
Good luck,
Jim
________________________________
I'm not sure where I'm going, but I'm having fun getting there........
'99 TJ sport; dark green, 6cyl/5 spd, Dana 30(aussie lkr)/35(lsd); 3.73, Skyjacker 2.5" lift, procomp 32x11.50-15 MT
CrackerJim is offline
post #3 of 7 Old 02-23-2008, 01:49 PM
daveg13
daveg13's Avatar
Drill and good bits?
daveg13 is offline
post #4 of 7 Old 02-23-2008, 02:06 PM
$lick
its called pb blaster.
1997 Wrangler 2.5L 5spd
Suspension specs:
RE 3.5, 1.25 JKS BL
Old Man Emu shocks
Teraflex adjustable front trac bar
JKS Disco's
Axle specs:
Dana 30- Superior 4.88's
Detriot tru-trac locker
Dana 35- Superior 4.88's
Riding on:
33x12.50 BFG A/T
Black Cragar soft 8's
$lick is offline
post #5 of 7 Old 02-23-2008, 02:16 PM Thread Starter
jmkeo74
The bolt that's stripped is the one that holds the track rod to the axle housing. There's a flag nut behind it. I'd cut it off, but am not sure that I'll be able to remove the rest of the bolt and nut...
I realized it was going to be a challenge last night when I turned the first nut...on the top side of the front shocks. I broke them both off. I then sprayed PB Blaster on every nut and bolt imagineable. I went back out today to find it didn't help much. I sprayed 'em all again!
I just got back from Sears with a 1 1/4" socket...bad information from someone that told me that was the size of the nut on the Pitman Arm. It's not. Anyone know what size it is???
jmkeo74 is offline
post #6 of 7 Old 02-23-2008, 02:29 PM
Bandicoot
I would just buy a large adjustable wrench - mine opens to over 2" and I have used it for the pitman arm nut, adjustable control arms, etc...
Bandicoot is offline
post #7 of 7 Old 02-23-2008, 03:00 PM
boriqua97
that pitman arm nut is a 33 mm, i just finished installing my 4 inch rc lift kit this week. and i too have a 97 TJ, I sprayed all of my bolts with Pb and a few of them gave me some touble but the rest came out alright. I had a lot of problems with the piman arm though. But one thing that was mentioned to me on this board was that unless I was lifting the jeep more than 5.5 inches that I would not need to change the pitman arm. I haven't tested it out yet b/c I am waiting on my new tires. But as soon as I get them I have to check to see if I have bump steer b/c of the drop pitman arm. good luck with your lift.
97 SE
Auto tranny w/Currie deep dish auto tranny oil pan, D30/35 w/ 3.73's, 4" RCX lift, 1.25JKS BL w/1" MML 32x11.50 Maxxis Bighorn on 15x8 Crager Black "D" 342's
Custom Stinger with Shackles on the front, Tire carrier/bumper in the back, skids/armor from radiator to the rear diff.
boriqua97 is offline
Lift Install Problems.... Unlimited04 TJ Wrangler Technical Forum 22 04-20-2010 05:43 PM
New Lift Install; couple problems laxin4life23 TJ Wrangler Technical Forum 24 04-12-2009 11:18 AM
Problems with lift install No Fear Jeep TJ Wrangler Technical Forum 3 06-16-2007 02:34 PM
More Problems with Lift Install rjkjoe TJ Wrangler Technical Forum 11 09-25-2005 11:13 AM
several problems since my re 4.5 lift install incubus2012 TJ Wrangler Technical Forum 6 05-25-2005 11:06 AM
