lift kit, how high is too high? - JeepForum.com
post #1 of 50 Old 02-10-2015, 10:21 AM Thread Starter
Airfrm
I have been thinking about putting a lift on my 97. I currently have a 2" rough country and wanted to move up to at least a 4" so I can put 35" tires under it; however, thinking about the phrase go big or go home, I have been eyeing the 6" lift but from past experience lifting a short wheelbase vehicle too much creates many problems with drive shafts and u joints. So my question, is 4" big enough to fit 35" under it, and if I went with either the 4 or 6, what other stuff do I have to look at? Thanks.
Airfrm is offline
post #2 of 50 Old 02-10-2015, 10:22 AM
biffgnar
biffgnar's Avatar
biffgnar is offline
post #3 of 50 Old 02-10-2015, 10:22 AM
blubaru2002
I've had 8 inch springs and 6 inch springs in the past.
I'm currently on 2.5 inch lift springs, 1 inch BL, and 35's.
No need for excessive lift height like 6 inches.
Originally Posted by Patrick Bateman
I have to return some video tapes.
blubaru2002 is offline
post #4 of 50 Old 02-10-2015, 10:31 AM
Ironhead
Originally Posted by Airfrm View Post
go big or go home
IMO, anything more than whats necessary to clear your tires is too high
that phrase does not equate to most offroaders.
reminds me of "fear this" or "its a jeep thing"
Ironhead is offline
post #5 of 50 Old 02-10-2015, 10:31 AM
Unlimited04
This post/info=my opinion
Unlimited04's Avatar
some run 37s on 2" of lift, others run 33s or 35s on 6" of lift. It depends on what you're after...frame clearance? belly clearance? tire clearance? articulation? compromise of all? or the best of all?
I run 33s on ~2.5" of lift with about 16" under the belly pan. It's a compromise like everything else, but it's been working very well for what I've done so far.
There's plenty of build threads on this forum, and links in my signature to keep you busy reading and learning for the next year or more.
Useful Write-Ups:
Fabrication & Build:
Funny:
Unlimited04 is offline
post #6 of 50 Old 02-10-2015, 10:32 AM
jjvw
jjvw's Avatar
If you have more spring lift than available suspension travel, then you arguably have too much lift. Is 30" of belly clearance on 30" tires a thoughtful build? Maybe for someone out there. Those are exaggerated numbers, btw.
2003 Rubicon
jjvw is offline
post #7 of 50 Old 02-10-2015, 12:21 PM
CharlieHo
When I decided to lift my TJ, I did my due diligence and researched for a year or so before spending any money. I ended up going with Savvy and their 4" lift, UCF belly skid to get that crap out of the way, all other related parts and pieces for it all to work correctly, and 33" TSLs.
It has all worked flawlessly, and I believe everything is top quality, but, if I were to do it all over again, I'd look for less lift. Heck, maybe less lift and more tire. Sometime in the future, I may drop it down a little, and start high lining it to fit.
Originally Posted by mdm
You could ask it nicely to move over. When that doesn't work, get a bar or 2x4 and ask it again.
I have the ability to spell correctly, it's just that the autocorrect on my iPad will not permit it.
CharlieHo is offline
post #8 of 50 Old 02-10-2015, 12:26 PM
TheBoogieman
Devil's Advocate
TheBoogieman's Avatar
4.25" lift with 35's.
Originally Posted by jeepinmichguy_ View Post
TheBoogieman is a jerk.
Why also would he need a rare as hen's teeth Dana 44 out of another TJ which will eventually lead to him swapping in a POS 8.8 because he can't find one?
TheBoogieman is offline
post #9 of 50 Old 02-10-2015, 01:30 PM
Shark_13
I wouldn't go more than 4" personally....
Shark_13 is offline
post #10 of 50 Old 02-10-2015, 02:25 PM
joe_jeep
On short arms 4" to 4.5" inches is about as tall as I would go, imho.
On long arms u could go taller, but I see little reason to do so.
in the end, its all a matter of opinion.
Many of us want to be as low as possible, and still fit our desired tires.
glfwda #6624
2005 rubicon sahara lj #592
joe_jeep is offline
post #11 of 50 Old 02-10-2015, 04:08 PM
329892 - Deactivated
Guest
this should be a photo thread.....
329892 - Deactivated is offline
post #12 of 50 Old 02-10-2015, 04:20 PM
Guest
Actually too high is when you lose the ability to corner or sidehill. Height & width need to be engineered together. The philosophy of an LJ being capable of higher lifts forgets LJs & TJs are the same width.
post #13 of 50 Old 02-10-2015, 04:33 PM
BigRodney
I have 5.5" long arm lift and am running 35s. It's too tall in my opinion. Extreme driveline angles and it's a pain to get in and out of for a 5' 10" short guy. I bought it that way and have been dialing it in since I bought it. If I were doing it I'd do a 1" body lift to increase air flow and facilitate a tummy tuck and 3" spring lift or so.
BigRodney is offline
post #14 of 50 Old 02-10-2015, 07:33 PM
FAW-CAN-ADIAN
That's what I was thinking..I was hoping to see some of the retarded hack jobs some think are cool.
FAW-CAN-ADIAN is offline
post #15 of 50 Old 02-10-2015, 07:54 PM
TheBoogieman
Devil's Advocate
I think I had a pic of the same Jeep before he painted the wheels black.
