Lift Kit Advice - JeepForum.com
post #1 of 29 Old 02-10-2014, 11:20 PM Thread Starter
99TJer93
Lift Kit Advice
I've got a 99 TJ that is stock besides the 31" Procomp's I put on in the fall. Now that spring is approaching I'd like to upgrade my suspension and install a lift kit. I'm thinking a 3" kit from either RCD or Full Traction, they'd both come with Bilstein shocks so they both sound good to me. I'd like some input or suggestions however before I commit to anything. Thanks!
99TJer93 is offline
post #2 of 29 Old 02-10-2014, 11:52 PM
dadkinsemt
Honestly, both kits are economy lifts. Most advice you receive will be to buy something more expensive, because it is higher quality. Really between the two, I doubt there is any difference in quality.
For what its worth, as you just put on new tires, may just want to do a a1" budget boost or body lift. Give you a little more room in the fenders without changing a lot. I think you may be disappointed in the look of you new 31s with a 3" lift.
Dusty
05 LJ rubicon
dadkinsemt is offline
post #3 of 29 Old 02-11-2014, 12:13 AM Thread Starter
99TJer93
Is there a budget boost that would be better than another? Could I put new shocks all the way around for a smoother ride? If so would any shock do or is there specific sizes for specific lift heights?
99TJer93 is offline
post #4 of 29 Old 02-11-2014, 12:19 AM
TheBoogieman
The Devil's Advocate
TheBoogieman's Avatar
Go with OME 2.5" if ride quality is an issue.Zone 2" BB is a good riding lift and perfect for 31's.Add a 1.25" BL for 33's.
TheBoogieman is offline
post #5 of 29 Old 02-11-2014, 12:26 AM Thread Starter
99TJer93
http://m.quadratec.com/products/prod...id=16090+00X+A
So I'd be all set if I picked that up? I wouldn't need anything else?
99TJer93 is offline
post #6 of 29 Old 02-11-2014, 12:35 AM Thread Starter
99TJer93
I've heard good things about OME too
99TJer93 is offline
post #7 of 29 Old 02-11-2014, 12:57 AM
1shotwonder
Both are economy lifts... They can cut prices because they don't give you stuff that you should really have to fully complete the lift, and have cheaper quality stuff
You're not getting longer shocks, longer sway links, longer brake lines, longer control arms.. etc etc.. Some of the packages may have some, but not all
Just for comparison, i'm looking at a 3.5lift long travel kit that's 3700$...
http://www.quadratec.com/products/16064_41X_PG.htm
http://www.metalcloak.com/TJ-LJ-Wran...Kit-p/7151.htm
See the difference with all the stuff you get?
If you can wait a few more months, I can give you my 2"bb, with shocks for cheap
Save 1000 elk. Smoke a wolf pack
Sometimes the light at the end of the tunnel is a muzzle flash
1shotwonder is offline
post #8 of 29 Old 02-11-2014, 05:25 AM
tyvanwie
That should be it.
tyvanwie is offline
post #9 of 29 Old 02-11-2014, 05:29 AM
MrSundays
If you're going with OME get the Nitro shocks or spend the extra to get Bilsteins. I'll let you on a hint, Quadratec is definitely not the cheapest place to buy OME parts.
SOLD- '13 JKR with lots of goodies
Current- '98 TJ Sahara: build coming in October
MrSundays is offline
post #10 of 29 Old 02-11-2014, 05:46 AM Thread Starter
99TJer93
So buy the OME 2" kit and buy the Bilsteins after? Or should I just buy the springs and shocks separate and make like a custom kit? And give me another hint, where might that be?
99TJer93 is offline
post #11 of 29 Old 02-11-2014, 05:59 AM
Duck Doctor
Go with the OME shocks. Contact dirk at DPG off road.
Duck Doctor is offline
post #12 of 29 Old 02-11-2014, 06:15 AM Thread Starter
99TJer93
Ill give them a call. Thanks!
99TJer93 is offline
post #13 of 29 Old 02-11-2014, 08:32 AM
MrSundays
Good setup. Won't be disappointed.
post #14 of 29 Old 02-11-2014, 08:55 AM
Ross
Don't fall into the having to spend a butt load of money trap when it comes to getting your Jeep off-road capable.
There is good info in post #4. 33s will get you a long way down the trial.
Your biggest issue will be your rear axle. If you have the dana 44 you are good. If you have the dana 35 and you want thing bigger or tougher you will probably want to address your rear axle before an expensive lift.
01 TJ, 34 Super Swaper 34x10.5 bias, Winch, locked, belly up, some armor, 4.0, 5spd
Ross is online now
post #15 of 29 Old 02-11-2014, 09:02 AM Thread Starter
99TJer93
So if I wanna run 33's in the future the 2.5 OME is a good start with the addition of a 1.25" bl? But I'd have to upgrade the rear axle only?
99TJer93 is offline
3" lift , lift kit advice , tj lift kits
