Lift Install Problems.... - Page 2 - JeepForum.com
post #16 of 23 Old 05-16-2009, 07:52 PM
Knuckelhead
AFSOC Retired
Knuckelhead's Avatar
Boulder.
I'm going to try drilling more first. Dremel second. An air chisel will be the last resort. There just isn't much room in that area...
BFH and a punch?...
Knuckelhead is offline
post #17 of 23 Old 05-16-2009, 07:54 PM
flexsaharatj
I went to Harbor Freight... and got this thing came with a chisel and drill bits and like 20 mins later bam all 4 bolts came out... it was like a miracle
flexsaharatj is offline
post #18 of 23 Old 05-16-2009, 08:16 PM
TR0423
i hate to say it man but i just spent a few days fighting the 3 rear upper shock bolts that snapped off while replacing my shocks. tried easy outs, tried drilling. ended up dropping the tank to get access and just get a sharp chisel and a 3lb. and get whacking. the metal right there is 2 layered so theres still something to put your new hardware on but just cut the weld with the chisel. and if your rusty on the bottom plan on new carrage bolts for the tank as i ended up replacing half of those too.
2003 TJ Rubicon 'Tomb Raider' Edition #0423
5.5" RockKrawler X factor LA,Skid Row plates,Warn 9000Xi and some other stuff and things...
TR0423 is offline
post #19 of 23 Old 05-16-2009, 08:25 PM
NEastUnlmtd
Try the search function. Or check your sig for links...
NEastUnlmtd is offline
post #20 of 23 Old 05-16-2009, 08:27 PM Thread Starter
Unlimited04
This post/info=my opinion
Unlimited04's Avatar
The search function was helpful. Found more about drilling & removing the stubborn weld-nuts. But my sig doesn't have any links to deal with this problem, so its not going to help.
Useful Write-Ups:
Fabrication & Build:
Funny:
Unlimited04 is offline
post #21 of 23 Old 05-17-2009, 02:33 PM
JESSETHELJ
JESSETHELJ's Avatar
So any luck man? Maybe you could do a write up on how to fix this lol.
2004 LJ*RIP Love * Ex-Wife Stole you and Sold you *Current 1999 XJ Heep
JESSETHELJ is offline
post #22 of 23 Old 04-20-2010, 05:35 PM
redpony03
see you been living w/everything for a while now, would you do anything different? what do you really like, anything you really hate?
redpony03 is offline
post #23 of 23 Old 04-20-2010, 05:43 PM Thread Starter
Unlimited04
see here:
http://www.jeepforum.com/forum/f9/un...-build-778715/
To do it again, I wouldn't do the adjustable front track bar. I'd weld on a reinforcement for the stock track bar & redrill the hole. My JKS track bar hits the Riddler diff cover pretty bad.
Oh, and the shock mount drilling was ultimately successful. 3-in-1 oil and a 1/16" drill bit that was at least 70 years old did the trick. Bored through the 10.9 steel like plastic! Once the pilot hole was in, the cobalt steel bit worked great at removing the rest of the hard steel.
Useful Write-Ups:
Funny:
lift kit install problems... jmkeo74 TJ Wrangler Technical Forum 6 02-23-2008 03:00 PM
Problems with lift install No Fear Jeep TJ Wrangler Technical Forum 3 06-16-2007 02:34 PM
small problems after lift install zoomin0074 YJ Wrangler Technical Forum 1 04-08-2007 02:14 AM
More Problems with Lift Install rjkjoe TJ Wrangler Technical Forum 11 09-25-2005 11:13 AM
several problems since my re 4.5 lift install incubus2012 TJ Wrangler Technical Forum 6 05-25-2005 11:06 AM
