Lift help for 35" tires and installation - JeepForum.com
post #1 of 5 Old 07-19-2010, 03:59 PM Thread Starter
JSY
Hi guys. I'm new to the forum and have a couple of questions...
First off, with suspension lifts, do you guys install your own?
If not, could you give me an estimation of cost for a shop to do it?
I'm planing on 35" tires, so I've figured I need 4" of lift. Does that sound good? Also does anyone have any suggestions on which kit I get? It'll be about 50/50 appearance/function. I've heard some have much better rides than others...
Thanks in advance...
JSY is offline
post #2 of 5 Old 07-19-2010, 04:01 PM
Unlimited04
This post/info=my opinion
Unlimited04's Avatar
start here:
http://www.jeepforum.com/forum/f9/tj...embers-722109/
http://www.jeepforum.com/forum/f9/i-...-my-tj-751873/
Useful Write-Ups:
Fabrication & Build:
Funny:
Unlimited04 is offline
post #3 of 5 Old 07-19-2010, 04:03 PM Thread Starter
JSY
Alright thanks. (that was a really fast reply!!!)
JSY is offline
post #4 of 5 Old 07-19-2010, 05:51 PM
vohk
Likely because that particular question gets asked several times a week, the answer changes very little, and some people get very aggravated when dead horses are beaten into a fine pulp. If you search around a little, you can find many excellent and comprehensive threads on the topic already.
vohk is offline
post #5 of 5 Old 07-19-2010, 06:05 PM
GOLENJEEPTJ
Running Secretly Amok!
GOLENJEEPTJ's Avatar
They would be known as "Stickys"! Or the search button is a great resource also?
GOLENJEEPTJ is offline
lift , suspension , 35 , install , installation , TJ
2.5 RC lift installation Latitude TJ Wrangler Technical Forum 29 01-19-2010 07:51 AM
New Rubicon Lift + New 33" Tires = Wobble (is this part of the installation process?) tandbwms TJ Wrangler Technical Forum 14 05-29-2009 05:08 PM
OBA installation problems and, what products work good to air down and then air tires BudmanV6 YJ Wrangler Technical Forum 2 06-03-2005 08:39 AM
installation of lift? ginsy YJ Wrangler Technical Forum 14 01-18-2005 07:36 PM
What Next after lift installation Help turbotempo85 YJ Wrangler Technical Forum 14 10-05-2004 09:29 AM
