Lift help! - JeepForum.com
post #1 of 9 Old 07-28-2012, 11:51 AM Thread Starter
zachtsouprakos
Lift help!
I just got my first wrangler, its all stock but i want to put a lift on it which would be able to fit 33"s. what kind of lift would let me lift the truck without dropping to t-case and would be able to fit 33's?
zachtsouprakos is offline
post #2 of 9 Old 07-28-2012, 12:11 PM
Vinnie911
Look at the rancho budget lifts. It all depends on your money circumstances. The zone 4.25 lift is a good choice too.
Vinnie911 is offline
post #3 of 9 Old 07-29-2012, 03:32 PM
dlysle
i run V8 ZJ springs up front(about 2.25" of lift) with a 1.75" coil spacer in the rear and with 1.25" wheel spacers and 7" flares i fit 33's with no problem. i have an '06 LJ, so i don't have any issues with driveline vibes, but i've heard that some TJ's do at as little as 2" of lift. if you get vibes that would mean a t-case drop at least or ideally a SYE and new rear driveshaft.
hope that helps
'You may not realize it when it happens, but a kick in the teeth may be the best thing in the world for you.' - Walt Disney, Animator, Film Producer
'four wheel drive only allows you to get stuck in more inaccessible places' - George Noll
dlysle is offline
post #4 of 9 Old 07-29-2012, 03:33 PM
TheBoogieman
Disturbed
TheBoogieman's Avatar
Zone 4.25" lift.If funds are tight,you can fit 33's with a 2"BB and 1.25"BL (pictured).
TheBoogieman is offline
post #5 of 9 Old 07-29-2012, 06:26 PM
the_great_white
^^^^^^that's a good looking jeep!!!
the_great_white is offline
post #6 of 9 Old 07-30-2012, 01:06 PM Thread Starter
zachtsouprakos
thats awesome thanks a lot guys, i wouldnt be able to fit 33's on a stock tj right? i need some lift?
post #7 of 9 Old 07-30-2012, 01:15 PM
biffgnar
biffgnar's Avatar
If you mean by "fit" to mount them in your driveway and take pictures of it sitting still, sure. But if you mean actually driving it anywhere not a great idea.
Romney in 2020!
biffgnar is offline
post #8 of 9 Old 07-30-2012, 05:25 PM
Vinnie911
Lol thats funny. A pictures worth a thousand words ehhh
post #9 of 9 Old 07-31-2012, 07:40 AM Thread Starter
zachtsouprakos
no i mean actually drive, so maybe 31's will fit
help needed , lift + spacers , tj , wrangler
Newbie Lift ? - Body lift vs. suspension lift yj_ryn TJ Wrangler Technical Forum 25 10-09-2013 07:51 PM
time to lift my 91 yj what is a good cheap lift and what 1" body lift drenter17 YJ Wrangler Technical Forum 34 06-23-2012 02:45 PM
Confused. Why 4" suspension lift plus body lift instead of taller suspension lift? ezgoin TJ Wrangler Technical Forum 34 02-12-2011 06:04 PM
Can I do this? Adding more lift to RC Series II 4" lift. Body lift or coil spacers? gattaca37 TJ Wrangler Technical Forum 20 09-12-2010 08:13 PM
New Rough Country 2.5 Progressive rate Spring Lift and 1.25 Body Lift qf4phlyer JK Wrangler Technical Forum 7 11-24-2008 05:59 PM
