Lift Advice- can't sort through it all - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > TJ Wrangler Technical Forum > Lift Advice- can't sort through it all
Ruffstuff 10 year saleBDS 4-1/2" Suspension Lift Kit - Jeep Wrangler YJRough Country Lift Kits and Parts!
Unread 08-12-2012, 03:51 PM   #1
vavision
I need help finding the right lift. I'm having trouble wading through the torrents of information about lifts. My Jeep has 160,000 miles on the stock suspension. It's well overdue for a replacement and I want to add some height at the same time.
Here are my assumptions
- 3'' is about right since anymore requires some drive train upgrades
- Since I plan to upgrade the springs and shocks anyway, no need for a BB spacer solution
- Short arm is cheaper (than LA), bolts on and is more than adequate since I've a very light off roader
-It's possible to get something decent for a 80% onroad 20% off road jeep for ~$600
So, here's where I need your help. The best place for me to throw this on my jeep myself is a few hours away. I need a decent quality kit that has everything I need so I can hammer everything out in a weekend. I feel I can throw the lift on, do a 1'' body lift and be good to go.
vavision is offline   Reply With Quote Quick reply to this message
Unread 08-12-2012, 03:54 PM   #2
vavision
Brand advice is another area I'm no sure about. For instance, would this be a good kit with everything I need to be good to go?
http://www.xtremeterrain.com/3suspen...neoffroad.aspx
Unread 08-12-2012, 04:29 PM   #3
Ironhead
there are hundreds of threads just like this
brands seem to go Savvy>OME>Bds\Zone>all the rest
best budget lift is usually the zone 3" or 4.25" combo.
I dont see any reason why you would want to go long arm
most all kits can be done by anyone in a few hours. do yourself a favor and do some research. take your time. know where you want your jeep to end before you start building. there is a lot more to a lift than springs and shocks. then that rolls into what size tires, which rolls into gears. it can get pretty expensive if you start buying parts twice
Ironhead is offline   Reply With Quote Quick reply to this message
Unread 08-12-2012, 04:52 PM   #4
otisdog
2008 WK
Seriously consider the OME 2.5" which will net you 3". Known for the best ride bar-none.
As said then BDS, Savvy etc. Get a good lift with good shocks.
Look here at the OME lifts:
http://dpgoffroad.com/?field_1=11&fi...it=Search+Site
You can add a 1" body lift if needed for clearance
Jim
08 Grand Cherokee Overland
otisdog is offline   Reply With Quote Quick reply to this message
Unread 08-12-2012, 05:30 PM   #5
99_TJ_Wyoming
dont even waste your time looking at Savvy or OME, stick to RC, BDS, and Zone.
99_TJ_Wyoming is offline   Reply With Quote Quick reply to this message
Unread 08-12-2012, 05:36 PM   #6
Vic99TJ
What's wrong with savvy?
Vic99TJ is offline   Reply With Quote Quick reply to this message
Unread 08-12-2012, 05:36 PM   #7
RubiconRazorbac
RubiconRazorbac's Avatar
dont even waste your time looking at Savvy or OME, stick to RC...
Yep, go crappy or go home.
Zone & BDS are good budget suspensions. Stay away from RC, skyjacker, FT, others sold through 4WP dealers.
Your shaft isn't long enough to handle that kind of droop...
My build thread: http://www.jeepforum.com/forum/f9/ru...thread-792423/
RubiconRazorbac is offline   Reply With Quote Quick reply to this message
Unread 08-12-2012, 05:37 PM   #8
99_TJ_Wyoming
Nothing at all.
Unread 08-12-2012, 05:40 PM   #9
RubiconRazorbac
Nothing. He's a hater.
Unread 08-12-2012, 05:55 PM   #10
99_TJ_Wyoming
LMAO ! ! ! ! oh yeah, I'm a hater I hate people who have one answer for every question.
I'm sorry OP, you should look at only Savvy and OME, you should be able to get 2 shocks and maybe even a spring for your $600.
Instead of "go crappy or go home" maybe you should have said "spend more than you can afford or park your POS"
Unread 08-13-2012, 12:36 PM   #11
vavision
Thanks.
How do you feel about the 3 inch Zone that I posted?
I don't see the point in throwing a lot of money at this jeep. It's got 160k on the clock, it's a 2.5L, it's a commuter when I don't feel like riding the bike (4-5 times a month). Had a guy slash my windows (doors were unlocked as always), and realized I really just wanted a little extra pride in ownership. Add some height while fixing the worn out suspension, flush mount the rear lights and do some other minor things.
The most off roading it gets is getting to my favorite kayak launch points and she does it pretty well with my worn out stock suspension. However, it can get hung up a bit on some of the trails I go on with friends and snow in the winter.
Unread 08-13-2012, 12:42 PM   #12
99_TJ_Wyoming
Zone is a very popular choice, they are a good economical lift from all I have read, I havent had one myself but havent seen anything negative about the cost or the product. At 3", you should have a simple install, nothing tricky and nothing to modify to make it work properly, its a good hieght to start with and at a good price.
The only suggestion I would make is try it first without the transfer case drop, when I had my 3.25" I ran it without the drop, if you have vibrations you can always install it, but mine didnt need it. Also you could consider a 1.25" body lift and 1" motor mount lift, also a great option to loose vibrations and not clearance.
Unread 08-13-2012, 04:22 PM   #13
otisdog
2008 WK
Yea put some springs on there and especially make sure you get some real cheap shocks on there. You'll love the ride.
If you want a good ride invest some cash, if you don't care go cheap.
Jim
Unread 08-13-2012, 05:19 PM   #14
vavision
Jim
All the reviews I've found say the Zone rides really nice. Do you not agree with that?
Unread 08-13-2012, 06:06 PM   #15
G Beasley
Its more than you want to pay , and does not account for all the wore out bushings in your control arms but it will ride exceptionally better than what you have now.
4-OME Shocks, 4-OME Coil Springs, OME Rear Trackbar Bracket, rear bumpstop extensions and Steering Stabilizer. $794.23
http://dpgoffroad.com/products/old-m...-wrangler-kit/
G Beasley is offline   Reply With Quote Quick reply to this message
2.5l , 3" , lift
