Liberty or GC CRD Swap? - Page 2 - JeepForum.com
post #16 of 29 Old 07-28-2010, 02:05 PM
turtlerace
Best taken in small doses
turtlerace's Avatar
1979 J-Series Truck
Originally Posted by USAFRecon View Post
Well definetly need to find a wrecked 07-08 WK. Seems to have a very stout diesel in it compared to the libbey.
2007-2008 3.0 L OM642 V6215 hp (160 kW)376 lbft (510 Nm)
Yeah, it seems to be a monster, but not sure a TJ frame would hold up to it.
Miss Amy's sensibilities and the language filter prevent me from telling you what I really think about you.
turtlerace is offline
post #17 of 29 Old 07-28-2010, 02:07 PM Thread Starter
USAFRecon
Why not? People are puttin 6.1s in em and V10 Viper engines. Don't see why not.
USAFRecon is offline
post #18 of 29 Old 07-28-2010, 02:13 PM
turtlerace
turtlerace's Avatar
1979 J-Series Truck
Almost 400 lb-ft of torque is pretty rough on a small frame like they have. We put a 427 in a Toyota pickup once, the torque buckled the front of the bed.
post #19 of 29 Old 07-28-2010, 02:14 PM Thread Starter
USAFRecon
Wonder how those guys with the 6.1s are doin it then?
post #20 of 29 Old 07-28-2010, 02:16 PM
turtlerace
turtlerace's Avatar
1979 J-Series Truck
I would guess they are either reinforcing the frame (which would incidentally take all of the needed flex out of it) or doing customs.
post #21 of 29 Old 07-28-2010, 03:20 PM Thread Starter
USAFRecon
Ah ok gotcha, maybe I will give some of those 6.1 build threads a look see
post #22 of 29 Old 07-29-2010, 10:07 AM Thread Starter
USAFRecon
Looks really expensive to do this
From Turbo Diesel 2.8 CRD in a TJ/LJ solved..... - Expedition Portal Forum
Burnsville Offroad was finally able to pull off a full conversion where everything works. AEV was the first to do this, but they will not do another. Burnsville was able to pull it off by swapping the dash cluster and steering column from the Liberty. They also had to swap in a set of JK axles in order to get the ABS speed signal that the computers need ( for cruise control if I remember correctly ). Burnsville also pulled off a 6-speed manual conversion with the Rubicon 4:1 transfer case for you gear grinders.
As a note.
-Full backspacing JK wheels would pull the width down to the same as 17" AEV Pinters on TJ axles.
-AEV was able to pull off this conversion by using a small interface computer between the liberty computers and TJ dash cluster.
-Hotwire also did one conversion but was missing the ABS signal so the Cruise control would not work and they had some automatic transmission control glitches.
-Green Diesel Engineering is also doing some very interesting work on reprogramming the engine control computer.
It looks extremely complicated and maybe needs pros to do this.
Don't have the money for anything like this or the know how for that matter. I wanted to do it all myself. Maybe I need to look into 4BTswaps.com It may be just a bit easier and cost friendly.
post #23 of 29 Old 07-29-2010, 10:41 AM
breckboarder55
Do it!
In a perfect world I would have one TJ with an L33 for a crawler, and an LJ with a diesel for an expedition rig... Add the genright Safari gas tank... that would be sweet.
To Veterans past and present, thank you for your service!
99 Jeep Wrangler-Just another TJ on 33"s
55 Dodge Royal Lancer- Resto Project
87 Mazda RX-7 Turbo II-Built.
87 Mazda RX-7 SE-Burn Victim
01 Honda S2000DD
breckboarder55 is offline
post #24 of 29 Old 07-29-2010, 11:44 AM
Unlimited04
This post/info=my opinion
Unlimited04's Avatar
oh man...i'd love a diesel in my jeep...the CRD libby's kick my arse everyday on the street and in the mountains. they pull hills like nobody's business.
Useful Write-Ups:
Fabrication & Build:
Funny:
Unlimited04 is offline
post #25 of 29 Old 07-29-2010, 02:00 PM Thread Starter
USAFRecon
Yea but I see that it would be a very difficult swap but I just may attempt it. Won't worry bout the steering wheel from the Libby cause yea the Sahara does have cruise I could live without it. I will keep researching and maybe try to attempt this by summer of next year.
And it will be cheaper than a 4BT cause I won't need new axles
post #26 of 29 Old 07-29-2010, 02:13 PM
Wheelin98TJ
JEEP FREAK
Wheelin98TJ's Avatar
...Won't worry bout the steering wheel from the Libby cause yea the Sahara does have cruise I could live without it. ...
They are probably using the Liberty steering wheel and column to get around the Sentry key.
There are other ways to do this though.
You can swap the Liberty ignition cylinder and Sentry key module in to the TJ steering column.
Wheelin98TJ is offline
post #27 of 29 Old 07-29-2010, 02:17 PM Thread Starter
USAFRecon
Yea after reading up on this 2006 Jeep Wrangler TJ Unlimited - Common Rail Diesel Engine - 4 Wheel Drive & Sport Utility Magazine
I see this in there and you sir are correct
The steering column, instrument cluster, and 75 percent of the wiring harness were all incorporated into the Wrangler. That way, the sentry key that was originally with the Liberty crossed over to the Unlimited enabling all of the VIN protected modules from the diesel donor to be retained
post #28 of 29 Old 07-29-2010, 08:31 PM
Douglas S.
Check out some of the Land Rover drivetrains. I've been considering a 200tdi swap, but there are some issues to get around.
1991 Land Cruiser HDJ81
Douglas S. is offline
post #29 of 29 Old 02-13-2013, 06:49 PM
dougbrown
Did anyone make any head way with the swap? I really want a diesel in my jeep.
Backwoods coustom 4x4 club of NJ
Vice president!
Looking for new members!
dougbrown is offline
CRD , diesel , swap , liberty , Grand Cherokee , KJ , WK , motor swap , engine swap , diesel swap
Another 4.0 Swap question...head swap vs. full engine swap Mol YJ Wrangler Technical Forum 11 10-18-2010 04:11 AM
88 4 cyl swap transfer case swap to 89 6 cylinder ? YjShane YJ Wrangler Technical Forum 1 03-26-2010 04:11 PM
Gathering parts for Axle swap, SOA, and V8 swap... tank29 YJ Wrangler Technical Forum 7 12-03-2009 02:42 AM
HVAC Control Swap: Swap just the lower ac/heater housing, or all of it? Justin Brimm TJ Wrangler Technical Forum 5 12-20-2007 03:29 AM
does anybody know if the Jeep Liberty 2.8 Diesel Engine would swap into the yj Natedogg0669 YJ Wrangler Technical Forum 3 05-01-2007 10:43 PM
