leveling kit after lift kit - JeepForum.com
post #1 of 20 Old 07-06-2011, 10:15 PM Thread Starter
97TJSPRT
not so long ago i installed the pro comp stage I 2 inch lift kit into my 97 TJ. came with four new springs and shocks nothing major just a quick boost for the time being. my question is if i can add either a 1 inch or 1.25 inch spacer to the front to level out the jeep WITHOUT need to replace anything else (longer control arms, dropping the transfercase, etc.) please let me know because i would then technically have a 3" lift in the front end and most of what ive been able to research says 2" is the max you can lift a tj without needing to do more to the jeep. any input at all would help out thanks!
*******q[ _\ _\_ ]p********
******._(|||||||)_.******
******III"""""'''''""""'"'III******
Zombie Outbreak Response Unit #279
97TJSPRT is offline
post #2 of 20 Old 07-06-2011, 10:33 PM
ohtenwillys
pff... just do it
ohtenwillys is offline
post #3 of 20 Old 07-07-2011, 03:33 AM
TheBoogieman
Disturbed Jeepaholic
TheBoogieman's Avatar
Don't add more than 1" and you'll be fine.I always add 3/4" spacers up front to level mine out.
TheBoogieman is offline
post #4 of 20 Old 07-07-2011, 08:08 AM Thread Starter
97TJSPRT
thanks that looks great, what size tires are those?
97TJSPRT is offline
post #5 of 20 Old 07-07-2011, 08:11 AM Thread Starter
97TJSPRT
thanks boogieman that looks great, what size tires are those? and thats a 2 inch lift with 3/4 spacer up front?
97TJSPRT is offline
post #6 of 20 Old 07-07-2011, 08:16 AM
RyanBum
I have a 2.5" skyjacker lift. I recently installed a 1" spacer in the front to level it out. I didn't experience any more vibes when I put it in. I am also running 33x12.50's. Since this pic I've added a 1" spacer in the rear also because I didn't care for the level look, but you should be ok. The first pic is with the 1" up front, and the second pic is with the 1" all around.
It's a Jeep thing... You wouldn't understand!
Christian Jeep Club Member #47
RyanBum is offline
post #7 of 20 Old 07-07-2011, 08:20 AM
kfdjason7620
Gonna need an alignment after
kfdjason7620 is offline
post #8 of 20 Old 07-07-2011, 08:20 AM Thread Starter
97TJSPRT
did you have to replace the control arms and drop the transfer case for the 2.5" lift?
97TJSPRT is offline
post #9 of 20 Old 07-07-2011, 08:22 AM
kfdjason7620
I replaced nothing other than springs and shocks, 50k miles ago, 4" longer springs in the front and a 2.5" inch spacer in the back
post #10 of 20 Old 07-07-2011, 09:17 AM
RyanBum
Mine has the skyjacker control arms, but the stock arms would be fine. And when I had the spacer in the front only, a few washers to drop the TC was enough. I added the tc drop when I put in the rear spacer.
RyanBum is offline
post #11 of 20 Old 07-07-2011, 09:39 AM
Unlimited04
This post/info=my opinion
Unlimited04's Avatar
personally, I prefer fixing something right. That means a new set of springs of the proper spring rate and spring length.
heres how i leveled mine without the use of spacers.
http://www.jeepforum.com/forum/f9/un...l#post11066169
Useful Write-Ups:
Fabrication & Build:
Funny:
Unlimited04 is offline
post #12 of 20 Old 07-07-2011, 09:48 AM Thread Starter
97TJSPRT
do you have any pics you could throw up?
97TJSPRT is offline
post #13 of 20 Old 07-07-2011, 09:54 AM
RyanBum
Here are quite a few. If you have issues seeing them, let me know. I am uploading them from my droid so I don't know if it will work.
ForumRunner_20110707_115120.jpg   ForumRunner_20110707_115140.jpg   ForumRunner_20110707_115159.jpg   ForumRunner_20110707_115230.jpg   ForumRunner_20110707_115256.jpg
RyanBum is offline
post #14 of 20 Old 07-07-2011, 10:02 AM Thread Starter
97TJSPRT
looks great thanks man, what gears are u running for your 33s?
97TJSPRT is offline
post #15 of 20 Old 07-07-2011, 10:06 AM
RyanBum
They are 3.73's. It is just fine for me, and its my dd.
RyanBum is offline
leveling , leveling lift , lift , lift + spacers , suspension
Jk Wrangler Leveling kit or JK 1.5" Performance Leveling? BORRONGO JK Wrangler Technical Forum 5 07-03-2011 01:38 AM
leveling kit or lift kit? bob_351c TJ Wrangler Technical Forum 3 04-08-2011 01:21 AM
Leveling plus a little lift? private TJ Wrangler Technical Forum 11 01-22-2011 02:52 PM
Leveling Kit Vs. Lift Kit? LAJeepX JK Wrangler Technical Forum 5 10-24-2010 06:43 AM
Leveling after lift JTB51B TJ Wrangler Technical Forum 9 01-16-2007 07:44 PM
