Lets talk mid-arms - JeepForum.com
post #1 of 47 Old 01-26-2010, 12:45 PM Thread Starter
goldswim5
Lets talk mid-arms
I'm getting ready to 4-link the rear of my jeep, and have decided on mid arms. After a trip to SMORR I decided I'd be getting hung up to much with long arms, and the ride just sucks with short arms. So that leaves mid arms. What is the length range that would generally be considered mid arm? I'm going to be triangulating the uppers, is there any forumula that says what length the upper should be compared to the lower? I'm thinking somewhere around 24-26" lowers.
I've got 6 Johnny Joints, 2 bushings, a truss, and control arm mounts sitting here so once I get this figured out I'll be ready to start.
2005 Wrangler Unlimited
6 speed, hard top, bone stock
goldswim5 is offline
post #2 of 47 Old 01-26-2010, 01:00 PM
SierraDave
Tag for more info. I'd really like to do a mid-arm three-link on the front of my Rubi.
SierraDave is offline
post #3 of 47 Old 01-26-2010, 01:32 PM
mudb8
want it rite or rite now?
mudb8's Avatar
I've been working on a 26" mid arm kit for a while in my non existant spare time, haven't had time to finish the front track bar problems.....
26" is about what I figure will work the best from stock height to about 5" with 12-14" travel shocks. the unsprung spring length is an issue with lower lift hieghts and long travel that's not matched by using shock relocation, then there's tire/fender clearance issues without highlined fenders...
I want your factory 07-up take-off/thrown out JK front/rear Lower Control Arms! Bent ones are perfect also as long as the bushings and cold cut rings are in good shape/useable
ASE Certified Master Tech/Fabricator @ jeepwest.com
mudb8 is offline
post #4 of 47 Old 01-26-2010, 01:35 PM Thread Starter
goldswim5
Mud what would you aim for with the uppers with a 26" lower?
post #5 of 47 Old 01-26-2010, 01:37 PM
Imped
Imped's Avatar
The general rule of thumb for uppers is 70% of lower length. So, around 18.5-19" would likely work well. A link calculator really helps with determining link length and placement.
OlllllllO
IndyORV
Imped is offline
post #6 of 47 Old 01-26-2010, 01:43 PM Thread Starter
goldswim5
I believe that is for non-triangulated setups though right? I've been playing with the calculator for about an hour now, but I'm not exactly an expert on what the results mean.
post #7 of 47 Old 01-26-2010, 01:50 PM
mudb8
mudb8's Avatar
that depends on how "correct" you wanna build the links.
like imped4now said, about 70%.
I'm still working on a tri link that works for me..
set up like RE and some others, they merely act as a radius arm due to the mounting locations.
mudb8 is offline
post #8 of 47 Old 01-26-2010, 01:50 PM
Imped
Imped's Avatar
From what I've seen, it all depends on link placement. For example, most guys I've seen with Poly Perf's 4 link setup have longer uppers than lowers by a couple inches and it works great. I've not built a link suspension setup on my own so I'm still not fully familiar with the optimum placement/length numbers and how they effect squat, roll steer, etc. I fully intend to over-research the topic when the time comes so that I understand everything to a T.
OlllllllO
IndyORV
Imped is offline
post #9 of 47 Old 01-26-2010, 02:34 PM Thread Starter
goldswim5
This is what I'm looking to do. This is ATXZJ's old rig, 26" lowers and 32" uppers. I think that's what I'm going to go with if I can get it to work in the calculator.
post #10 of 47 Old 01-26-2010, 02:51 PM
Imped
Imped's Avatar
Yep, and I believe that's the Poly kit. Those are definitely the (beautiful) Poly frame mounts.
OlllllllO
IndyORV
Imped is offline
post #11 of 47 Old 01-26-2010, 02:53 PM Thread Starter
goldswim5
You would think so, he did a great job, but it's actually custom. You can see his build here:
Made some progress on the MidArm Project *PICS* - Page 2 - JeepsUnlimited.com Forums
post #12 of 47 Old 01-26-2010, 03:00 PM
Imped
Imped's Avatar
Why yes it is. I knew he did good work, but man.....
OlllllllO
IndyORV
Imped is offline
post #13 of 47 Old 01-26-2010, 03:05 PM
Dogman
Dogman's Avatar
It does look good and I'm wanting to go down the same road...the real question is why did he get rid of those to build a long arm set up?
John 3:17
Dogman is offline
post #14 of 47 Old 01-26-2010, 03:09 PM
Imped
Imped's Avatar
Probably like any of us--why get rid of short arms that work well? He probably just wanted to build something else for the hell of it. And he may have been thinking: "My jeep works better now with longer arms than it did with short arms. I wonder if the trend will continue with even longer arms....."
But I don't know, hopefully he contributes.
OlllllllO
IndyORV
Imped is offline
post #15 of 47 Old 01-26-2010, 03:49 PM
Dogman
Dogman's Avatar
No, that's not it I've read some of his comments and it was more along the line of "don't waste your time with mid-arms just to have to do it again." But, yes, hopefully he'll chime in and we can get his opinions.
Ultimately it's all about what set up you're going for and what you're going to do with it - but it's nice to talk with someone that has done it already.
John 3:17
Dogman is offline
lets talk MML MC_NickP TJ Wrangler Technical Forum 20 06-21-2009 11:35 AM
Lets Talk Lockers exerciz101 TJ Wrangler Technical Forum 2 03-15-2007 12:31 AM
Lets talk steering TJ=MT Pockets TJ Wrangler Technical Forum 6 10-17-2006 12:58 PM
lets talk a little about the 44 silvergreentj TJ Wrangler Technical Forum 14 02-12-2005 09:59 PM
lets talk engines 97sarah TJ Wrangler Technical Forum 11 02-15-2003 11:42 PM
