Let's see your custom fabbed axle end anti-sway bar link mounts. - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > TJ Wrangler Technical Forum > Let's see your custom fabbed axle end anti-sway bar link mounts.
Ruffstuff 10 year saleBDS 4-1/2" Suspension Lift Kit - Jeep Wrangler YJRough Country Lift Kits and Parts!
Unread 10-26-2009, 08:03 AM   #1
NotURMailman
I grossly over estimated the strenght of the angle iron I used to make the brackets to attach the sway bar links to the axle. The first time I got off camber they twisted like pretzels. It looked like some type of failed origami experiment. I have some ideas of how to make the new ones, but would like to see what some others have done. My passenger (my left( side is pretty cluttered up with bracketry right next to the diff. I obvioslu have to bring them all the way down to the tubes, because the driver's side actually bent the spring perch where I had attached them. just thought it would be a good idea to see some other ideas before I start getting into the fab. The passenger side will also most likely be used to mount the steering stabilizer. I had used 1 1/2"x 1 1/2"x 1/8" angle. they were 6" tall (off of the spring perches) to clear the steering. I'll see if I can find some pictures...
EDIT: Yeah, I see that I typod the title and left the "r" off, but I don't know how to fix that...
My RHD TJ - Savvy equipped... And loving it! - Durty Rok Carolina Offroad
I drive on the right side, what's wrong with you?
Be very careful with the wife mod. Uninstallation can be extremely expensive. Wife mods have been known to take the Jeep and all other mods during the uninstall process. Also, make sure you service your wife mod properly as often as humanly possible. Wife mods not properly serviced may malfunction or uninstall themselves at any time.
NotURMailman is offline   Reply With Quote Quick reply to this message
Unread 10-26-2009, 10:56 AM   #2
NotURMailman
Bump for lunch time crowd...
Unread 10-26-2009, 05:55 PM   #3
cj7Sswampers
1982 CJ7
Are you sure that thing is safe? It doesn't look like anything...
P$yCh0--82' CJ7--Chevy 305--T-176--Dana 300--39.5" Super Swamper TSL's--12" lift--S.O.A. Conversion--Old Sarge
EVERYTHING IS SUBJECT TO CHANGE
cj7Sswampers is offline   Reply With Quote Quick reply to this message
Unread 10-26-2009, 07:15 PM   #4
Fourbycor
Mine seems to have held up fine....
'02 YellowTJ Sport, 5-speed, Custom 4-link/3-link, King Coilover's, GenRight stuff, 37" Nitto's on Raceline's, Tom Woods Shafts, ARB's, RCV Shafts, Reid Knuckles, 5.13's, PSC Hydro assist, Rock Hard Cage, Warn M8000, Teralow 4:1.
Proud member of the 2011 & 2012 Ultimate Adventure
Fourbycor is offline   Reply With Quote Quick reply to this message
Unread 12-09-2009, 06:01 AM   #5
NotURMailman
That's the point, they didn't hold up at all and bent like pretzels. I have made a new one on the passenger side out of 1/4" plate, still have to do the driver's side one...
