let's punch my 42RLE in the THROAT! - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > TJ Wrangler Technical Forum > let's punch my 42RLE in the THROAT!
BDS 4-1/2" Suspension Lift Kit - Jeep Wrangler YJRough Country Lift Kits and Parts!FREE, FREE, FREE EVENT!! Save big on Lockers now till Apri
Unread 02-13-2012, 02:58 PM   #1
YEEHAW88
Hey guys!
Here's the deal, I was driving today and the check engine light threw a code: P0700 I know it's a generic code but it isn't showing any other specific codes at the moment. However, when the light came on i felt the tranny downshift a little harder than usual. It doesn't do this every time just on occasion. Therefore, with the light throwing a tranny code and feeling the difference in shifting I am thinking it could be the TCM. Any thoughts?
04 TJ X 4.0 4speed auto. 42RLE
As usual, Thanks guys!!
Don't worry, I learned this on Jeep Forum.
YEEHAW88 is offline   Reply With Quote Quick reply to this message
Unread 02-13-2012, 03:34 PM   #2
YEEHAW88
bumped
Unread 02-13-2012, 03:38 PM   #3
2006_Sport
Pretty sure p0700 isnt a trany code. And the 42rle is a clunky trans sometimes. It was probaby just the torque converter locking/unlocking
2006_Sport is offline   Reply With Quote Quick reply to this message
Unread 02-13-2012, 03:44 PM   #4
YEEHAW88
You are correct! Sorry about the confusion. I checked again and aparently it is an ETAX code? I know it still has to do with the PCM/TCM. I'm not to worried as you sid it's probably the torque converter. but I'd still like to get this code resolved.
Unread 02-13-2012, 03:51 PM   #5
2006_Sport
Take the positive cable off the battery for 30 seconds to a minute to clear it. If it comes back within a day. Get it looked at
Unread 02-13-2012, 04:52 PM   #6
Lawrence
P0700 is a general fault in the transmission. In the meantime, you can make sure your fluid level is good and clean and then disconnect the battery to reset it and see if the code comes back. Best would be to get a scan tool to further diagnose.
On a side note, I think the 42RLE is a big POS and I sometimes dream of a stick shift swap. [/SoapBox]
Lawrence is offline   Reply With Quote Quick reply to this message
Unread 02-13-2012, 04:56 PM   #7
Peterpsc
I have read here on the forum about what seems like a general unease with the 42rle. I have one and don't think it's a POS. Seems like it operates as designed.
Peterpsc is offline   Reply With Quote Quick reply to this message
Unread 02-13-2012, 04:57 PM   #8
2006_Sport
Yeah, i don't really have an issue with it. I just turn the OD off in the city and it drives like any other auto I've driven.
Unread 02-13-2012, 05:07 PM   #9
Sccafire
Everyone is correct in saying P0700 is a generic transmission code. All that code bsaically does is tell you the transmission has a problem. You will need a code reader that can read transmission codes to get the exact code.
Scott
"life is good at 2 MPH"
Sccafire is offline   Reply With Quote Quick reply to this message
Unread 02-13-2012, 05:10 PM   #10
drl650
I agree same here. No issues at all.
drl650 is offline   Reply With Quote Quick reply to this message
Unread 02-13-2012, 05:35 PM   #11
timberwolf0122
My OD goes off the moment I drive about 40, I'm seriously considering hooking an Arduino micro controller to the jeep to do this for me, but then again I'm a huge nerd.
Atheist Jeep Club Member #2
Doctor Who has died 13 times, is on his 14th regeneration and has a time machine, beat that Jesus.
timberwolf0122 is offline   Reply With Quote Quick reply to this message
Unread 02-13-2012, 06:12 PM   #12
Border Dave
Got Sand?
Border Dave's Avatar
All the problems of this tranny have been well documented on this forum. If you have a 42RLE you need to install a quality transmission fluid cooler and install lower gears than you would with a similar transmission. You can't expect it to drive well with 33s and 3.73 gearing.
Border Dave is offline   Reply With Quote Quick reply to this message
Unread 02-13-2012, 06:14 PM   #13
2006_Sport
Funny you should say this. Mine drives OKAY on 33s and 3.73s but my 33s are really a big 32 inch tire since they are BFGs.
