left turn signal error noise - JeepForum.com
post #1 of 2 Old 02-02-2011, 09:19 PM Thread Starter
Jsnherron
took my 01 tj out wheelin the other weekend and have spent the last 2 weeks fixin all the things i messed up, jus about everythings done with but my left turn signal..... It doesnt blink, it comes on but wont blink and makes an annoying kinda error noise whenever its on
im pretty sure it is because of all the water cuz it went thru alot, jus wondering were it got to and what i need to replace?? any ideas
Jsnherron is offline
post #2 of 2 Old 02-02-2011, 09:25 PM
Jeepster83
most likely theres water where the bulb(s) is/are shorting the circuit. get some wd-40 and spray a bit in the front and rear light bulb sockets then dry them out. check it again after that.
also, its not very common but a bad relay can cause the stuck on problem too.
Being right has nothing to do with arrogance. It's only perceived that way by those that are wrong.
WyoTech West Sacramento - Graduated 8/19/2011
Back into my Jeep... finally.
Jeepster83 is offline
turn signal
Left turn signal not cancel : left lower clock-style cancel spring? stilllearning6 YJ Wrangler Technical Forum 6 05-07-2010 12:00 PM
New turn signal switch, no left signal? sasquachYJ YJ Wrangler Technical Forum 4 01-25-2010 09:07 PM
Left Turn Signal Problem PINKBOYD TJ Wrangler Technical Forum 2 12-09-2009 04:30 AM
Left Turn Signal Won't Re-Set Dan Marino YJ Wrangler Technical Forum 28 06-24-2007 01:43 PM
Left Turn Signal trapman TJ Wrangler Technical Forum 6 01-15-2007 06:27 PM
