Left to right rear axle play normal? - JeepForum.com
post #1 of 2 Old 07-27-2010, 10:20 PM Thread Starter
autopc25
I have a automatic 97 TJ with 138K miles. I had the car up on a lift when replacing shocks. I moved the rear wheel back and forth from driver side to passenger side, pushing and pulling as if your were taking the wheel off. I noticed a little play as I was pushing and pulling the wheel. Probably less then .025" in and out. The car runs fine, no noises or leaks of any kind. Is this normal?
autopc25 is offline
post #2 of 2 Old 07-27-2010, 11:24 PM
SILASPRIT
Yes, that is just the axle hitting the cross pin when pushing the axle in and hitting the c-clip when pulling out the axle.
-SOLD-
1997 Grand Cherokee 5.2 Limited - D44a Trussed 4.10 Gears - HP30 4.10 Gears - NP242 - IRO HnT - IRO Custom Drive Shaft - 4.5" lift - JKS Quicker Disconnects -
RC Front ADJ. Trackbar - IRO Rear ADJ. Trackbar - Rusty's Lower ADJ. CA's - Front tow hooks - Rear OE Hitch - T-Case Skid -
Gas Tank Skid - Bilstein 5125's - 31" MTR's - Magnaflow SS Muffler - 1.25" Wheel Spacers - Custom Rock Sliders - Cobra 19 DXIV
I am an Authorized IRO dealer!!
SILASPRIT is offline
axle play , axle , trac bar , track bar , tj , wrangler
Rear Axle Offset - Normal? Jeepin72 TJ Wrangler Technical Forum 7 03-27-2010 02:37 PM
completely sheared off rear left axle... Beerman621 TJ Wrangler Technical Forum 11 02-19-2010 09:43 PM
? Rear D44 Axle Play ? Something Loose ? Kubiron TJ Wrangler Technical Forum 0 03-13-2009 07:50 PM
Normal steering box play? itasor TJ Wrangler Technical Forum 9 01-14-2009 02:36 PM
Is this much driveline play normal? vetdezracer TJ Wrangler Technical Forum 1 06-30-2007 05:10 PM
