LEDs - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > TJ Wrangler Technical Forum > LEDs
ARTEC JK UNDER ARMOR - 4 door Bellypan KitsPoison Spyder DeFender Inner Fender KitsCess Recovery Gear Snatch Tow Strap OffRoad @ ROCKRIDGE4WD
Unread 04-01-2012, 04:42 PM   #1
kbman
LEDs
I know this is everywhere but i cant find everything i need led gauge cluster.
97 tj
so far i think i need 5 74's for the gauges, 2 74's for the heat and ac.
what size do i need for my high beam light in the gauges and for the factory fog light/rear defrost switch
probably gonna do red but still on the fence hopefully ill order them tonight
kbman is offline   Reply With Quote
Unread 04-01-2012, 05:11 PM   #2
mpoo1083
haven't done this yet, just another thing on a long list, but here is the link i saved for it http://www.jeepforum.com/forum/f9/ga...nstall-752937/
mpoo1083 is offline   Reply With Quote
Unread 04-02-2012, 06:51 PM   #3
kbman
just ordered from superbright led's gonna instal this week asap
Unread 04-02-2012, 07:05 PM   #4
shatteredsoul
I did this on my 98, I ended up frying the two that went into the temp. control panel. I bought the 3 LED bulbs and the metal in the twist lock touched the circuits on the bulbs. I ended up getting 2 more 74's that has the single LED and all is good now. There is a little difference in the brightness levels but I can deal with that.
shatteredsoul is offline   Reply With Quote
Unread 04-03-2012, 07:54 PM   #5
kbman
ok and guess what i ordered....the same ones u fried. hopefully i wont have any issues
Unread 04-04-2012, 05:00 PM   #6
kbman
put them in today and the ones in the gauges r fine but the ones in the heat slider fried right away just watched them smoke and then swore. SO ANYONE OUT THERE DO NOT BUY THE HIGH POWER LED'S WITH 3 LED'S ON THEM. just stick with the cheaper ones.
Unread 04-04-2012, 07:05 PM   #7
shatteredsoul
I talked to them on the phone for 45 minutes trying to figure out my issue. It simply boiled down to the circuit board sitting too low and touching the metal in the twist lock connector. The 1 LED bulbs work perfect though but not as bright.
Unread 12-05-2013, 07:59 AM   #8
TJeep_1999
I also have a '97 and wanted to confirm you needed:
(5) 74's for the gauge Cluster
(2) 74's for the heat and ac (Think this is different on newer TJ's)
I also didn't see a reply for the Lower Buttons (over drive, defog, ect) but believe they are:
two bulbs per switch:
size: one t3 and one t4 (Several listed... what base and/or P/N should I get???)
Also, does the dimmer work with LED's or are you fixed to one level of brightness?
Thank you in advance...
TJeep_1999 is offline   Reply With Quote
Unread 12-09-2013, 06:09 PM   #9
TJeep_1999
I'll update my own post for any who find this via search. For the '97 you'll need:
(5) 3LED 74's for the gauge Cluster
(2) 3LED 74's for the heat and ac (It is different on newer TJ's)
(3) NEO4 4mm lights for the switched
(2) NEO3 3mm for the indicator lights on the fog and defrost switches - I went with Green and Amber to color match existing indicator lights
