LED Turn Signal Installation - Page 4 - JeepForum.com
post #46 of 80 Old 09-11-2013, 04:55 PM
D0T-C0M
2014 JK Wrangler
Originally Posted by Salgreatest9 View Post
http://www.ebay.com/itm/300930352319
i bought these? theirs only two wires. Would I still have to do the same process ? with the diodes and transistor?
I used a resistor and diode only, no transistor
D0T-C0M is offline
post #47 of 80 Old 09-11-2013, 05:32 PM
Salgreatest9
Why not the diodes ?
Salgreatest9 is offline
post #48 of 80 Old 09-11-2013, 05:36 PM
D0T-C0M
2014 JK Wrangler
Brain fart, Of course you need diodes, its the transistors you don't need.
D0T-C0M is offline
post #49 of 80 Old 09-17-2013, 11:54 AM
kfdjason7620
I am doing this exact mod today. I feel like I am in High school again, soldering these diodes and resistors. Kinda fun! And instead of buying the led flasher, I am gonna modify the current one to not blink fast
kfdjason7620 is offline
post #50 of 80 Old 09-17-2013, 12:54 PM
Salgreatest9
I bought an after market flasher
But I think I'm also gonna modify my old one
I don't like how my new clicks as it flashes
post #51 of 80 Old 12-10-2013, 06:54 AM
Echo5
Thanks for the write up, it saved me a lot of time.
Originally Posted by noise_maker View Post
After some trial and error i landed on 100 ohm so as to have decently bright marker lights but have a good differentiation between the turn and the marker while the head lights are on.
I also had better results using a 100 ohm 1/2 watt resistor.
Echo5 is offline
post #52 of 80 Old 12-11-2013, 12:02 AM
redjeepguy1
Just finished this myself today, and I added these in my MCE flat fenders.
http://www.ledtrailerlights.com/cm/cm_M09300.htm
Bill
member 141,234,541 of the red jeep club
redjeepguy1 is offline
post #53 of 80 Old 12-11-2013, 12:04 AM
sjones26573
Subbed in case assistance is needed later on. This stuff is my forte.
The Offroad Club @ NC State; Founder
The Yellowtail Build
Jeep-Owner.com
sjones26573 is offline
post #54 of 80 Old 01-15-2014, 11:41 AM
NortheastBay
Just installed some MC fenders which have a 2-wire LED under the inner fenderwell and a 2-wire LED at the front of the fender. Questions is, would I be wiring each LED per the OP's direction, with the intent of having both LEDs function as parking and turn together, for each fender? Will I need to use less resistance since I will have two LEDs coming off of one harness?
I'm currently wired with the parking light wire to the inner fenderwell and the turn signal wire to the front of the fender. The turn signal LED remains dark until activated.
Thanks for the help!
Robert
NortheastBay is offline
post #55 of 80 Old 01-16-2014, 12:55 PM
rpapp1
Led turn signal probs
Hey I have an 03 Rubicon and have followed your steps to the tee and I've came to a problem. The lights work but it continues to make that error sound when I try to use the blinkers which still don't blink. Any help with this will be greatly appreciated. I am currently checking into the led flasher which I havnt installed yet and will let you know what happens. Thanks.
rubicon27
rpapp1 is offline
post #56 of 80 Old 01-20-2014, 12:05 AM
Crawlmachine
I'm ready to build my Diodes/resistor circuit. My TJ is a 2004.
Here's my Q: I already mod my OEM flasher relay to work with LED's all around. So I wonder if i still need to use a resistor behind the diode? What's the resistor for??
Looking for a "Grumpy" Front bumper for my TJ from Road Armor
Crawlmachine is offline
post #57 of 80 Old 01-20-2014, 02:17 PM
Jonny Jeep
Jonny Jeep's Avatar
LEDs provide a very low load to the flasher relay. The resistor is to provide a load so the indicators don'r flash fast when using a standard flasher relay. If you've done the mod to you're flasher relay you don't need the resistors.
Jonny Jeep is offline
post #58 of 80 Old 01-20-2014, 03:38 PM
LA-Sahara
No, the resistor is there to give the LED only half power for "running light" mode. Then when the resistor is bypassed, it's lights up full power for turn signals.
Subbed for quick reference. Just ordered up some triangle LEDs for my tube fender project.
LA-Sahara is offline
post #59 of 80 Old 01-20-2014, 04:40 PM
Crawlmachine
Thanks guys for your input. So anyone else can confirm?
post #60 of 80 Old 01-21-2014, 10:41 AM
Jonny Jeep
Jonny Jeep's Avatar
I was drinking ale while on the internet last night and just looked at the title of the thread being "Led Turn Signal Installation".
If you just meant the side markers LA-Sahara is correct, the resistors lower the brighness of the LEDs when just the marker lights are on.
Load resistors or flasher relay mod/LED flasher relay swap are only needed if the main front or rear turn signal bulbs are being swapped for LEDs.
led , turn signal , write up , write-up , installation , install , tj , wrangler
Broken turn signal lever, Need to turn OFF hi-beams Tulsachokehold YJ Wrangler Technical Forum 16 12-10-2014 12:39 AM
Headlights/Turn Signal turn on Wipers...HELP! r3b0w TJ Wrangler Technical Forum 16 06-07-2010 01:59 AM
New turn signal switch, no left signal? sasquachYJ YJ Wrangler Technical Forum 4 01-25-2010 09:07 PM
Driver side rear turn signal -- no signal --chris-- YJ Wrangler Technical Forum 5 02-23-2008 07:43 PM
Turn signal to fast, brake/turn fuses blowing and a gas gauge with an identity chrisi pyro9862 YJ Wrangler Technical Forum 3 06-29-2005 01:35 PM
