LED Turn Signal Installation - Page 3 - JeepForum.com
post #31 of 80 Old 10-21-2012, 01:28 PM
snowrydr01
In base anyone finds this later here is what I did. The two wire side marker must have a chassis ground because the wires are the same as the running and blinker to the front. So to get blinking side markers also you just need to to the same two to three wire conversion with the diodes and resisters just use the front lights ground wires. Since my lights were being mounted so close to each other I just soldered them all together and it works fine.
snowrydr01 is offline
post #32 of 80 Old 10-21-2012, 03:13 PM
silver97tj
silver97tj's Avatar
Finally some who can solder right and shrinkwrap!!!..................................... ..... You woulndt believe how many people use black tape or worse duct tape!!!
1998 Blue TJ, 4 Cyl., Auto (30rh), Hardtop with installed Sunroof, mostly stock.
31x10.5x15 Mud Tires, TJ Rubicon springs, Mopar Deep Trans Pan and Cooler
Army Vet and proud of it! Have you served your country?
Support our Troops!! Thank You!!!
silver97tj is offline
post #33 of 80 Old 10-21-2012, 05:02 PM
snowrydr01
Still used electrical tape for some joints. I didn't have the right size shrink wrap and wanted to be done. Or soldered the joint and realized I shade for gifted to put it on first. Oh well
post #34 of 80 Old 02-28-2013, 07:46 AM
Eddie13f
I know I'm reviving an old thread, but I am looking for some confirmation. If I am converting to all LEDs (all 4 corners of the TJ), how must I wire the front in order to have sidemarkers and turn signals work like stock. My thought process has lead me to believe that I will do the following:
Convert the turn signals (2 inch round 2 wire LED) to a 3 wire using 2 diodes and a resistor, connect directly into the 3 wire turn signal harness (stock)
Convert the side marker (3/4" round 2 wire LED) to a 3 wire using 2 diodes and a resistor, connect the 2 lives wires (stock 2 wire side marker wiring) to the two diode links and then ground the LED to the frame.
Will this give me stock results where the lights will work with the headlights on/parking lights on/ all lights off?
Thanks!
Eddie13f is offline
post #35 of 80 Old 02-28-2013, 12:14 PM
Jonny Jeep
Jonny Jeep's Avatar
Hi Eddie, The two to three wire conversion on the side marker will mean it lights dull when the lights come on,
and flashes bright at the same time as the front lamp whether the lights are on or not.
You will loose the wig-wag effect when the lights are on as the side marker will light up brighter instead of going out.
Jonny Jeep is offline
post #36 of 80 Old 02-28-2013, 12:27 PM
Eddie13f
So basically, doing the 2 to 3 wire conversion on the side markers AS WELL AS the front signals will allow all 4 LEDs up front to work as a turn signal regardless of whether or not the parking lights/headlights are on? I understand that the side markers will be 1/2 as dim as parking lights then get fully bright when I have the turn signal on. But is grounding the side marker to a frame ground or common ground the proper move?
Eddie13f is offline
post #37 of 80 Old 02-28-2013, 01:16 PM
Jonny Jeep
Jonny Jeep's Avatar
Correct.
Tap the ground wire going to the front turn/markers for the side LEDs.
That way they'll ground through the loom to the ground points on the rear of the grill near each headlamp.
post #38 of 80 Old 02-28-2013, 01:30 PM
Eddie13f
That makes sense. Thanks so much for your input. Couldn't I also run wires from the front turn signal (between the LED and the diodes/resistor) to the side marker? That way I wouldn't use the stock side marker wires at all and would onlt need a total of 4 diodes and 2 resistors?
Eddie13f is offline
post #39 of 80 Old 02-28-2013, 02:39 PM
Jonny Jeep
Jonny Jeep's Avatar
You could run the wires from between the front lamp and diodes/resistor. I presume it would be OK and it would reduce the amount of joins in the wiring
compared to having two sets of diodes/resistor on each side of the Jeep.
I have a bundle of wire links with croc clips so I'd be tempted to wire it up off the vehicle and test it to see if seems OK, before soldering and heatshrinking it all up.
post #40 of 80 Old 03-20-2013, 04:12 PM
drivengsxr1000
Originally Posted by boomerjeep View Post
the ep26 flasher you mentioned, is this the same one that is located inside the steering column in a 02 tj?
same question here looking for the relay now and can not find it
drivengsxr1000 is offline
post #41 of 80 Old 07-29-2013, 06:21 PM
Arctycfox
http://www.genright.com/ProductInfo....0#.UfcBOeD-NaN
Arctycfox is offline
post #42 of 80 Old 07-29-2013, 06:21 PM
Arctycfox
Ok, so 2006 LJ. My front right, forward facing parking light/turn signal went out. I bought some 3/4" LED turn signals, and am going to install them below the headlights, reminescent of the ol' CJ's. Problem I'm having is how to wire the 2-wire LED's to do as the side/flair mounted lights work (ie: stay on during parking lights and flash during a turn). Once the forward facing bulb is blown, the flair light only fast flashes during turns, but will not stay on when not. I am going to order the flasher relay from GenRight, but still need to wire them in the mean time.
It's looking like Diodes are what other people have tried, but I don't see how it will work.......
seems like one side of the diode pack will supply 12v when p-lights are on, and the other side will supply 12v when the turn siganls flash. but if voltage is always present on at least one wire the LED will stay on, and not flash....
And why does the side marker light no longer work at all? Does a wire need to "pass through" the forward facing light?
post #43 of 80 Old 07-31-2013, 07:22 AM
D0T-C0M
2014 JK Wrangler
Originally Posted by Jamesbbh View Post
Sorry for replying to an old post but I want to know where you got your amber signal lights. I have the same tube fender setup and I really like the way these triangle shaped lights fit the bumper.
D0T-C0M is offline
post #44 of 80 Old 07-31-2013, 07:44 PM
SpeedJeep
A friend of mine has something similar on his sport bike. I'm not sure if they're the same but it's a possible place to start.
Edit: Is this it?
http://www.lockhartphillipsusa.com/L...MBER-LENS.html
With sufficient thrust, pigs fly just fine.
SpeedJeep is offline
post #45 of 80 Old 09-11-2013, 04:20 PM
Salgreatest9
http://www.ebay.com/itm/300930352319
i bought these? theirs only two wires. Would I still have to do the same process ? with the diodes and transistor?
Salgreatest9 is offline
led , turn signal , write up , write-up , installation , install , tj , wrangler
Broken turn signal lever, Need to turn OFF hi-beams Tulsachokehold YJ Wrangler Technical Forum 16 12-10-2014 12:39 AM
Headlights/Turn Signal turn on Wipers...HELP! r3b0w TJ Wrangler Technical Forum 16 06-07-2010 01:59 AM
New turn signal switch, no left signal? sasquachYJ YJ Wrangler Technical Forum 4 01-25-2010 09:07 PM
Driver side rear turn signal -- no signal --chris-- YJ Wrangler Technical Forum 5 02-23-2008 07:43 PM
Turn signal to fast, brake/turn fuses blowing and a gas gauge with an identity chrisi pyro9862 YJ Wrangler Technical Forum 3 06-29-2005 01:35 PM
