LED Tailight question - JeepForum.com
post #1 of 7 Old 01-16-2009, 12:01 PM Thread Starter
njsjeep
I replaced my stock tail lights with some sealed low profile ones I found at a local tractor supply place. The lights work but since the LEDs have less resistance than the old bulbs the turn signals operate about twice as fast. I didn't put a meter on the either the old or new set so I have no idea of the exact difference. Any ideas on an easy fix, new relay, add a resistor etc.?
thanks
njsjeep is offline
post #2 of 7 Old 01-16-2009, 12:05 PM
Bmel17
add a relay; search LEDs for jeeps ton of sites have them
06 TJ Black GOLDEN EAGLE Edition
96 Buick Creep Wagon
08 HD Nightster
Bmel17 is offline
post #3 of 7 Old 01-16-2009, 12:07 PM
19OlllllllO41
19OlllllllO41's Avatar
You just need to get a "heavy duty flasher". You can buy em at any auto parts store. Its the little silver thing about the size of a golf ball that is mounted up under the dash above the drivers feet, to the left of the steering column.
The Present:
'05 TJ Rubicon (Electric Lime Green)
'04 WJ
'46 CJ2A
The Past:
'83 CJ7, '92 YJ, '00 XJ, '99 TJ, '05 TJ Rubicon (Impact Orange)
19OlllllllO41 is offline
post #4 of 7 Old 01-16-2009, 12:14 PM
bdevr
check out stu-offroad.com. He has a write up on there on how to modify the stoock relay. Worked great for me
bdevr is offline
post #5 of 7 Old 01-16-2009, 12:34 PM
bctj
X2 on the stu offroad. I also fixed my flasher for free. Be careful when cutting the foil. I helped a friend do another one and we wrecked it. cost 30 for the new LED Flasher.
bctj is offline
post #6 of 7 Old 01-16-2009, 12:51 PM
Sccafire
Sccafire is offline
post #7 of 7 Old 01-16-2009, 01:14 PM Thread Starter
njsjeep
Thanks for all the replies
njsjeep is offline
led tailight help (already searched) gottkts YJ Wrangler Technical Forum 13 01-18-2010 06:18 PM
busted tailight question kaybone TJ Wrangler Technical Forum 2 03-06-2008 11:48 AM
Led Tailight problem-Help quick Please Dangle TJ Wrangler Technical Forum 6 01-30-2006 04:06 PM
Replacement Tailight housing's? FXSTCHEWY TJ Wrangler Technical Forum 2 04-06-2005 11:18 PM
Need some tailight help Special Ed YJ Wrangler Technical Forum 5 03-10-2004 10:03 AM
