LED Tail Light Problem - JeepForum.com
post #1 of 4 Old 01-27-2014, 08:49 PM Thread Starter
quentinp35
okay so i installed or i am in the process of installing LED taillights flush mounted. i have ran into a problem and can not seem to figure out the solution. installed drivers side tailight and works fine (just the fast flash). installed passenger side and its acting all kinds of stupid
it comes on and sometimes my turn signal indicator stays on and when i turn signal on it just buzzes or does nothing and random. emergency flashers work fine.
what could be the problem?
-grounding issue?
-needs new flasher?
help please need to get back on road asap.
quentinp35 is offline
post #2 of 4 Old 01-27-2014, 09:56 PM Thread Starter
quentinp35
Now no running lights in my tail lights. Probably a fuse. Gonna track it down in the morning and go get a ep27 flasher
post #3 of 4 Old 01-27-2014, 10:13 PM
Jonathanjr1
I seen this video on you tube of a guy installing leds on a cherokee. He used a trailer converter box to get the running break and turn signals to work.
Heres the video it might help.
http://www.youtube.com/watch?app=des...&v=aHjKqACSu4A
Jonathanjr1 is offline
post #4 of 4 Old 01-28-2014, 09:05 AM
festerw
festerw's Avatar
Triple check the ground on that side.
LM470 is the correct flasher for your 05, the EP27 will work but the signals will still work after the ignition is shut off.
Also a trailer wiring box isn't necessary for a TJ.
Hers - 2011 Dodge Durango Crew
Mine - 2003 Jeep Wrangler X
1998 Jeep Cherokee Classic
festerw is online now
led , tail lights
