LED lights wont turn off - JeepForum.com
post #1 of 3 Old 08-18-2012, 10:00 PM Thread Starter
tri486
So I replaced all my lights inside the cab with LED's ( driver, passenger feet, and overhead light). Somehow they are still being powered but at half the power. I have my lights/door hooked to a switch so when my door are off I can hit the switch to turn the beeping and lights off. But when I hit the switch to turn it on, the lights turn on to full power any ideas? When I had the original bulbs in they never were lit half way only with the LED's.
Thank you
Running over pot holes is the closest thing to 4x4 in the city....
tri486 is offline
post #2 of 3 Old 08-19-2012, 04:15 PM
aparke4
i had the same issue... i think since LED's require such little power, a resistor is required in line with the + 12 volt in to the light... i do not know which resistor - maybe some one else can post up!
aparke4 is offline
post #3 of 3 Old 08-19-2012, 07:12 PM Thread Starter
tri486
Cool, I will try one out. Thank you I like your profile pic. haha
tri486 is offline
cab , led , light , lights
Fog lights WON'T turn off... Now Highbeams wont come on!!!! chris4jeep TJ Wrangler Technical Forum 8 01-21-2013 03:07 PM
interior lights wont turn off... jeepin-gheenoe TJ Wrangler Technical Forum 3 10-28-2010 10:28 PM
stock fog lights wont turn on help!!!!!! 04wranglerX2 TJ Wrangler Technical Forum 12 01-11-2010 08:58 PM
Parking lights wont turn off geoff11 TJ Wrangler Technical Forum 1 03-15-2007 02:49 PM
Fog lights wont turn off. surfer TJ Wrangler Technical Forum 1 03-14-2007 11:48 AM
