LED light pod problem - JeepForum.com
post #1 of 5 Old 05-17-2011, 07:43 PM Thread Starter
mhcurlee
I bought a Vision LED light POD as a backup light for my Jeep.
This one: http://visionxsuperstore.com/Solstic...XIL-S1103.aspx
I did a test connection to my factory purple backup wire and all worked fine. I just connected the wires with some test wires with alligator clips (the pod not mounted to the Jeep).
I then mounted the LED pod and wired it in for good. I then started up the Jeep and tested again, but the LED pod didn't work. I then cut the wires at my first splice and used the alligator clip wires to perform the test again, this time with the pod mounted to the Jeep. I then noticed arcing when I tried to connect the positive wire and the LED pod would not come on. I then removed the pod from the Jeeps bumper and tested again. This time no arch and the pod worked fine.
Why would this happen simply because the pod is grounded to the Jeep? The housing of the pod is aluminum and I know it's somehow not working just because it comes in contact with the Jeeps body. It seems like if I had some sort of positive shorting to the Jeeps body I would have other issues (like blown fuses) and not just problems with the LED lights. Could it be a short between the LED pods case and the positive wire in the pod itself?
The only mods to my Jeep are rear LED tail lights (done by the PO) and a no-splice trailer light harness (I installed this myself.... just plug to the factory wiring harness). The LED lights are also installed correctly... the PO wired in factory light harness connectors to the LED's and didn't cut any of the factory wiring.
mhcurlee is offline
post #2 of 5 Old 05-17-2011, 07:54 PM
freeskier93
My guess if the housing is aluminum when it touches any metal on the jeep it grounds through the housing, which is going to be the path of least resistance and bypass the light to complete the circuit, therefore not blowing any fuses and shorting.
freeskier93 is offline
post #3 of 5 Old 05-17-2011, 08:23 PM Thread Starter
mhcurlee
Well I found the problem. It's the LED pod. I went back to my direct connection test and noticed that if you touch the ground to the case you get a short. I simply used my trailer light harness for the test. I made a video of the problem and will link to it after it uploads. I am going to call Vision tomorrow and see how good they are about shipping me a new LED pod. These things are expensive enough, so I hope they stand behind their products.
What sucks is that I wasted a ton of time just to fine a stupid defective part that I just spent good money on!!!!!
mhcurlee is offline
post #4 of 5 Old 05-17-2011, 09:05 PM Thread Starter
mhcurlee
mhcurlee is offline
post #5 of 5 Old 05-17-2011, 11:05 PM
Heath
2014 JK Wrangler
Sounds like an internal short.
2013 JKU Rubicon
Heath is offline
Light Problem suvee30 YJ Wrangler Technical Forum 0 08-24-2009 10:41 PM
LED Light Problem SanPatricio TJ Wrangler Technical Forum 3 12-11-2008 08:03 PM
oem fog light problem ziptychick TJ Wrangler Technical Forum 3 08-03-2008 06:05 PM
Heater problem + Interior Light problem Heartchill TJ Wrangler Technical Forum 1 10-19-2006 01:38 PM
4WD Light Problem jc_tj TJ Wrangler Technical Forum 3 01-10-2006 08:36 PM
