LED front turn signals don't work with headlights on - JeepForum.com
post #1 of 2 Old 01-13-2011, 10:51 AM Thread Starter
Jsnherron
I installed the smittybilt xrc front tube fenders a few months ago and put small LED turn signals ( one on each side) and tested them out ( during the day) and they worked... Well I just realized last week that with the headlights on ( they are HIDs if that matters) they don't work but work fine when they are off.... Any suggestions ???
Jsnherron is offline
post #2 of 2 Old 01-13-2011, 12:17 PM
WAC_Jeeper
WAC_Jeeper's Avatar
Sounds like you installed some 2-wire LEDs? (all of the small ones that I know of are 2-wire, as opposed to 3).
Due to the way the OE wiring is, the the polarity of the parking light and turn signal wires flip flops whether the parking lights are on or off. It actually has nothing to do with whether your headlights are on or off - just the parking lights (which happen to be on when the headlights are on). You can make the LEDs work correctly with a little soldering, some wire, 560 Ohm resistor, and 2 rectifier diodes.
Basically, find the parking light wire. Solder in the 560 Ohm resistor and then the diode. Then, solder in the diode on the blinker wire. After the diodes, combine these two wires together and what you get will be the + wire to the LED. Then, add a ground wire to go from the - side of the LED to the Jeep, there it's the body, frame, or a splice into a common ground.
The resistor will reduce the output of the LED by about 1/2-2/3 - which is still actually pretty bright. This will be the parking light setting. The LED will then come on full power for the blinker.
12 JKR 2 door, MCE Gen III Flares, Teraflex 1.5" Perfomance Leveling kit, 35" MTRs, ARB bars front/rear, ARB diff covers, ARB Dual Compressor, AEV DOT-compliant beadlocks, Warn Zeon 8
97 TJ, MCE fenders and flares, heavily used and reliable on 35's.
WAC_Jeeper is offline
turn signal
turn signals dont work with headlights on ktaylor448 TJ Wrangler Technical Forum 9 10-28-2010 08:08 PM
Turn signals only work when headlights on thisgardengrove TJ Wrangler Technical Forum 2 05-20-2010 10:44 AM
Turn signals don't work BobA TJ Wrangler Technical Forum 5 08-22-2008 09:36 PM
Turn signals don't work m3meems TJ Wrangler Technical Forum 9 07-13-2008 03:37 PM
Headlights, Brake Lights, Turn signals dont work Optik45 TJ Wrangler Technical Forum 3 07-22-2006 02:07 AM
