| Wild Boar Products Cargo Rack or Front Bumper Giveaway |
| Register | FAQ | Search | Today's Posts | Mark Forums Read | Search Members |
Thread Tools |
| #1 | |||
Registered User Join Date: Nov 2007 Location: In yo intanetz!? Posts: 1,749 | LED bulb in stock flare for parking/turn. Info needed
__________________ I'm sellin some stock items off my 2006 TJ CLICK HERE 4 THREAD w/ PICS | ||
| #2 | |
www.theknutters.com | A load equallizer is only needed when you change a normal lightbulb for a LED one in a turn signal circuit - they would not be used for under car lighting. THe reason why you need a equallizer is because the flasher circuit requires a certain amount of load to work properly. LED lights use much less energy and don't create enough load for the flasher to work correctly if at all, the equallizer adds load making the flasher work. Try Auto-zone they may have a flasher unit that will work with LED lights - if not then JC Whitney would be my next choice. You could always hit a local car stereo shop too. |
| #3 | ||
Registered User Join Date: Nov 2007 Location: In yo intanetz!? Posts: 1,749 | Quote:
Thanks for your response as well. __________________ I'm sellin some stock items off my 2006 TJ CLICK HERE 4 THREAD w/ PICS | |
| #4 | |
Registered User | ccj , if you do not replace flasher with an led flasher you can modify your own flasher here is a link to look at. http://www.stu-offroad.com/electrical/led1/led-3.htm i picked up my trico ep-26 flasher from Pep Boys |
| #5 | |
Registered User | sorry...just realized your friend has 05 here is the new link http://www.stu-offroad.com/electrical/led1/led-4.htm |
| #6 | |
Registered User | If you dont mind me asking... why does he wanna go with the LED's? Because they last longer? Stock signal-bulbs have been known to outlive some vehicles... Regular bulbs, in any color you want (I have blue under my clear frt shades at the moment) are like 5 bucks - and can be changed in a few minutes - is the intensity that great that it warrants a 4 to 500% price increase [for him] - not to mention the "equilized" issue or flasher replacement ?!?! just askin... ![]() ![]() __________________ 01 TJ SPORT - 4.0, 4" Lift on 16" MOABS /SSTs Post count CUT from over 1400 to 940 on 1/30/09 - What'd I do ? /l ,[___], l--L-⌐OlllllllO- ▒)ŻŻ ▒)--♂-▒) Criminals thrive on society's indulgence in tolerance |
| #7 | |||
![]() Quote:
| #8 | ||
Registered User | Quote:
no pun intended__________________ 01 TJ SPORT - 4.0, 4" Lift on 16" MOABS /SSTs Post count CUT from over 1400 to 940 on 1/30/09 - What'd I do ? /l ,[___], l--L-⌐OlllllllO- ▒)ŻŻ ▒)--♂-▒) Criminals thrive on society's indulgence in tolerance | |
| #9 | |
Registered User Join Date: Nov 2007 Location: In yo intanetz!? Posts: 1,749 | __________________ I'm sellin some stock items off my 2006 TJ CLICK HERE 4 THREAD w/ PICS |
| #10 | ||
www.theknutters.com | Quote:
| #11 | |
Registered User | deltabravo is Dougs user name from 4x4LED.com |
| #12 | |
GATORS---BCS CHAMPS!! | x2. __________________ Who wants an orange whip? Orange whip? Orange whip? Three orange whips. Sahara Jeep Club #23 White Jeep Club #225 |
| #13 | |||
![]() __________________ I'm sellin some stock items off my 2006 TJ CLICK HERE 4 THREAD w/ PICS | ||
| #14 | ||
Registered User | Someone's calling my name!!!! Quote:
The basically will end up looking like a little sport light shining through the lens. nearly all vehicle marker and tail lights rely a lot on the reflector to help spread the light and fill the lens. Those LEDs simply shine their light directly at the lens and will just show a little round dot of light. My experience has been that when trying to do LEDs in the front, especially if you already have LEDs in the rear, is they tend to act very strange, even when the correct LED style flasher is used. Side marker LEDs are a different beast all together. See the second diagram here: http://www.danielsternlighting.com/tech/markerflash/markerflash.html __________________ Doug www.4x4LED.com - LED lights for Jeeps, cars, trucks, trailers, etc.!! Tiedowns for your Jeep trailering needs! Envy4x4.com Suspension parts/kits, CBs and accessories and other Jeep doo-dads, MOLLE bags and packs too! | |
| #15 | ||
http://www.northridge4x4.com/proddetail.php?prod=FLASHER-RELAY __________________ Doug www.4x4LED.com - LED lights for Jeeps, cars, trucks, trailers, etc.!! Tiedowns for your Jeep trailering needs! Envy4x4.com Suspension parts/kits, CBs and accessories and other Jeep doo-dads, MOLLE bags and packs too! | |
| Thread Tools | |
| Thread | Thread Starter | Jeep Forums | Replies | Last Post |
| bulb ok dash indicator ok turn signal not ok | CostaRicaJeep | YJ Technical Forum | 19 | 04-26-2009 11:46 AM |
| keep blowing turn signal filament in parking light bulb on driver side...what the... | bortz1892 | TJ Technical Forum | 6 | 03-29-2009 02:15 PM |
| Turn signal bulb socket - sources | twhditto | TJ Technical Forum | 6 | 08-01-2008 04:48 PM |
| Fast Blink Turn Signal - Just Replaced Bulb | msavard | TJ Technical Forum | 16 | 07-31-2008 06:39 PM |
| turn/marker bulb socket corroded | Snowbird | YJ Technical Forum | 2 | 02-23-2003 04:10 PM |
Previous Thread
Next Thread
