Learned a lesson the HARD WAY regarding backspacing - JeepForum.com
post #1 of 30 Old 03-05-2011, 08:28 PM Thread Starter
VTXRubicon
I have a 2006 Rubicon with a 4" Lift.
When I bought it the jeep had 33x15.5x16 Mickey Thompsons. They were too wide and had lots of bump steer.
I bought some factory rims and put 31x10.5x15 BFG's on the jeep. These looked ridiculous and caused it to be too unstable.
Using the 30 day buy back from Discount Tire, I got 33x12.50x15 Duratracs on the factory rims. Looked great and drove great.
Today after re-installing my new bumper and winch and new winch cable, I headed down the driveway when all of a sudden there was a loud woosh and the left rear hit the ground.
Get out, and the left rear is flat. Jacked it up and pulled the tire.
Due to not enough backspacing the tire rubbed on the top of the coil housing ?? and rubbed a groove in the tire. Pulled the right one and it was almost the same.
I am a lucky man because if that had happened at 70MPH I might not be here anymore.
Took the two tires to discount and they replaced them at no charge due to being 2 weeks old, and said that the tech should have caught that. Ended up buying MB Chaos 15" rims to get the offset I need and stop the rubbing.
Maybe I should buy a lottery ticket?
Jeep Jack Stands.jpg   Underside Rubber.jpg   ShinedCoil.jpg   NewRims.jpg   Width.jpg
VTXRubicon is offline
post #2 of 30 Old 03-05-2011, 08:56 PM
GilaMtnJeep
GilaMtnJeep's Avatar
33x12.5's + too little backspacing = spring perch induced tire failure. Glad you didn't have a wreck.
Silence is Golden, Duct tape comes in Many Colors.
Journeyman Meterman IBEW Local 611
Work with enthusiasm as though you were working for the Lord rather than for man.
Member 25
/l ,[____],
l---L -0lllllll0-
()_) ()_)-O-)_)
GilaMtnJeep is offline
post #3 of 30 Old 03-05-2011, 08:57 PM
jdub36
I like the new wheels. I am glad discount replaced those tires for you. I have always found their prices to be a little higher than other places but i have heard that they are good at standing behind their products.
jw
jdub36 is offline
post #4 of 30 Old 03-05-2011, 10:19 PM
TJDaveX
Glad you were not injured or worse. I have had great service from our local Discount Tire dealer. I am a repeat customer.
and...................................
That's a huge winch!!
TJDaveX is offline
post #5 of 30 Old 03-05-2011, 11:02 PM
EricsGreen98Tj
So what's the backspacing of the new rims?
Building my junk with more junk, so Im always on the look out for more junk....Free to cheap preferably. :D
My junk http://www.jeepforum.com/forum/f22/survivor-project-driveway-frame-swap-33s-build-1280626/index3.html
EricsGreen98Tj is offline
post #6 of 30 Old 03-05-2011, 11:14 PM
Tdaz250
1994 ZJ
Who uses 33x15.5.tires ? Sorry but that's too ****in wide IMO
94 ZJ 4.0
3.5 lift with 31 inch Toyo MT's
Tdaz250 is offline
post #7 of 30 Old 03-30-2011, 10:54 PM
dabrogger
which discount? the mall side or la quinta side of navarro?
dabrogger is offline
post #8 of 30 Old 03-31-2011, 12:52 AM
sxysouthtx
Wow, I was just thinking about throwing some 33's on mine. And being that your from neck of the woods (originally Corpus), glad to see you're ok. What back spacing did you go with? I want 33X12.50XR15's. Anyways, nice rig.
Not much motion in the ocean, but I'm the captain.
sxysouthtx is offline
post #9 of 30 Old 03-31-2011, 01:16 AM
Rbloodhound
Glad you at ok and that every thing worked out for you
Rbloodhound is offline
post #10 of 30 Old 03-31-2011, 02:40 AM
Davetha
Davetha's Avatar
Wow, damn that sucks. The metal looks like it got nice an polished though! You might want to spray it before it starts to rust though!
Davetha is offline
post #11 of 30 Old 03-31-2011, 05:01 AM
TheBoogieman
Deeply Disturbed
TheBoogieman's Avatar
You want 3.75-4.5" backspacing.The 4.5" will stick out less.I always run 3.75" backspaced wheels with 12.5" wide tires.
TheBoogieman is offline
post #12 of 30 Old 03-31-2011, 07:22 AM
GilaMtnJeep
4-1/2 may even be too little for 12.5's. Go for 3.75 so you don't have rubbing issues at full steering lock or when at full axle flex.
Member 25
/l ,[____],
l---L -0lllllll0-
()_) ()_)-O-)_)
post #13 of 30 Old 03-31-2011, 07:53 AM
NEastUnlmtd
From way back with CJs we always tried to stay narrow. I found some used rims and tires, they are way outset IDK the inches. They looked silly to me when I first mounted them up. After the recent mods first flexxing out the Jeep I realized how nice it was at full droop to have the extra width, the tire tucked in perfect and kept better footing. Plus the steering etc. advantages.
NEastUnlmtd is offline
post #14 of 30 Old 03-31-2011, 07:57 AM
Kip03TJ
what does the stock rubicon rims have, 4.5?
FOR SALE
14,960 miles perfect condition
2003 Jeep Wrangler Sahara edition fully loaded 5 speed manual. Brown dog 1" motor mounts, Currie 1" body lift, jks front disconnects, 31" Goodyear Wrangler duratracs, 8 adjustable control arms, Advance Adapters HD SYE, Tom woods premium driveshaft, driver & passenger heated seats
Kip03TJ is offline
post #15 of 30 Old 03-31-2011, 08:06 AM
Woodenya
No, 5 or 5.5.....
'06 TJ Rubi (Light Metalic Khaki) 6sp, Bought 3-10 w/6500 miles. 31 MTR's, UCF alum UHC T-case & engine skid w/ LoPro, Rokmen gas tank & steer gear skid, Ridler dif covers F/R, Warn 8274-50, Optima Yellow top, Pro Comp front 3/4" spacers, Currie 1" BL, Bomb Proof MML, Novak cable shifter, AGR Super Box 2, Warn rear bumper/tire carrier, Rubi locker mod/pumps moved to engine bay, OBA. Build to come...
Woodenya is offline
Lesson Learned... the hard way.... Bill M. Wrangler General Discussion 9 06-05-2009 04:38 PM
Lesson Learned Tuckerboy Wrangler General Discussion 9 12-02-2008 11:34 AM
Lesson Learned Grubbi TJ Wrangler Technical Forum 4 08-08-2008 07:10 AM
lesson learned......the hard way mud n rox TJ Wrangler Technical Forum 9 01-11-2006 11:34 PM
Lesson Learned Loose Screws TJ Wrangler Technical Forum 11 09-20-2005 09:56 AM
